Sony FD Trinitron KD-30XS955 30" TV Logo
Posted on Nov 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WHEN FIRST STARTED PICRURE LOOKS LIKE A BAD ANTENNA SIGNAL.AFTER STARTING A SECONDE TIME IT CLEARS RIGHT UP. SONY MODEL # KD-30XS955
Anonymous
Level 3:
  • Master 10,594 Answers
  • Posted on Nov 27, 2009
Anonymous
Master
Level 3:
Answers
10594
Questions
9
Helped
2955890
Points
33084
Please update tv channels data in memory.
Go to Menu and select Auto Search, TV will search all available tv channels and will store it in memory, this will update memory data and problem will be solved.
Thanks.
Sony KD-30xs955 television won't turn on.
Anthony from Infotech posted the solution at another location:
6 and 7 blink codes 90% of the time are failure of the two control chips on the DZ board IC8002 and IC6501 both are MCZ3001D available from www.mcmelectronics.com
An ability to solder well is required to do this
Alternate solutions are to send the board to www.ptscorp.com and they will replace the chips or replace the board subject to availibility
A technician would charge $350 for this depends where you are
Shuts off
Short circuit protection circuit energizes, and shuts the TV down to prevent further damages. Check for any short circuit at its main board components; especially to horizontal output transistor. Contact any service technician. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy.
1helpful
My fd trintron wega (kd-0xs955) will sound as if it is starting of when POWER is pressed then the red stand by blinks a few times and nothing else when it is just plugged into the wall (no cable connected)
The flashing light is "Code" for diagnostics. Count the flashes before it pauses. Some Sony user manuals will have the answer in the troubleshooting section of the manual. If you don't have your manual,
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KD30XS955
That's the link.
Hope this helps
We Have A Sony Trinitron KD-30XS955 That Refuses To Turn On. Every Time We Try To Turn It On We Get 6 To 7 Light Flickers On The Front.
You need to replace the mainboard of tv
the cost is to high and it is very difficult find
one..you better replace it
Sandby light flashing red/green will not trun on
Hi gm,
Welcome to FixYa.
My name is John.
I will be assisting you with your issue.
How many times does it blink?
Hello
How may I help you.
Let me know your question please.
Thanks.
Bad reception
Sounds like you have an antenna problem. Find where the antenna plugs into the radio. Unplug it and find a nail or something the same diameter as the center pin wrap about 3-5 turns of a four foot piece of wire around the nail and plug the nail into the antenna input on the radio. If it clears up reception you have a bad or grounded antenna. Follow the antenna wire back to the windshield or fender etc. mounted antenna, sometimes there are other plug in points that get knocked loose.
No signal unless on twin screen
Since the PIP is working properly, I would think that the set is hooked up properly. Make sure that the main picture (the one on the left), is on the proper Antenna input, I.e. antenna A. If the hook up is correct and all inputs are correct, then, the problem is probably the main tuner.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
