Apple 22" Cinema Display Monitor Logo
Posted on Nov 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My apple cinema display m8149 adc version i want to hook it up to my hp pc what card do i use that will work with my pc
Anonymous
Level 3:
  • Master 1,305 Answers
  • Posted on Nov 27, 2009
Anonymous
Master
Level 3:
Answers
1305
Questions
0
Helped
596411
Points
4327
Yep! just use an ADC to VGA adapter and you're good to go. Then set the resolution to suit.
I have a M8149 Cinema dispaly 22" and want to connect to late 2009 Mac mini. The monitor came with a strange adaptor set of ADC input to 1x each of usb, 24Pin 92x rows of 8) male ADC, and another plug...
The Apple 22" Cinema display M8149 (ADC) is one that is not compatible.
It might be better to find another brand display to work with your 2009 Mac Mini. The Apple model A1081 is DVI, but for the age (its 8 years old, the lamps are likely dimmer than new...) I would look for a resolution-compatible DVI input display (Dell Ultrasharp, etc..).
Apple M8149 22" LCD.
This will be a driver problem. Solutions can be found on the Apple Support website
Dear sir i have a apple cinema display m8149 lcd.i have loss my apple system(cpu) and want to run apple tft with other cpu (intel dvi and vga) tel me the how will conection or explane me where are RGB...
You can run that monitor from a DVI connection but you would need to get an adapter from DVI to ADC and that supplies power to the monitor. DrBott makes an adapter like this called the DVIator (http://www.dviator.com/) that should work for you if you other CPU has DVI out.
1helpful
Apple Cinema Display 22" M8149 Does this work with a pc computer?
Yes, I tried once 2 months ago, but you need DVI connector on your PC's Graphic Card
Apple Cinema display goes BLACK after start-up
My G4 has a ADC & VGA on the same card. The VGA works but the ADC, is doing the same thing as you described. I am searching the web, and can not find an answer to this problem. George 3/21/2010
22" Apple Cinema Display doesn't power on
This may be an issue with the display detecting the wrong video format or is using an unsupported resolution for this Apple Cinema Display 22"
Procedure:
• Make sure your Mac is turned off.
• Once your Mac is shutdown, you will need to perform what is called a PRAM reset (Parameter RAM)
• Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously .
• Turn on the computer.
• Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
• Now, hold the keys down until the computer restarts and you hear the start up sound for the third time.
• Release the keys and allow the Mac to start up.
If that does not help here is additional support reference from Apple regarding its LCD displays:
Apple Support Link:
Power Light Flash Issues
Let me know if this helps!
Regards,
-Mactechtrainer
1helpful
Need Repair Manual for Apple Cinema Display M8149
here is a manual for the 17 in. apple studio http://www.devicemanuals.com/guide/Display%20and%20Video/Apple/Apple-Apple-Studio-Display-(17-inch-CRT)-User%27s-TVRBek9BPT.html
Apple 20" display black screen
I've read that aftermarket DVI cable adapters don't work well with this set-up. You might try the Apple DVI to ADC adapter. It's expensive but I see them on eBay or craigslist from time to time at less than half the normal $99 cost.
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
