Maytag MZD2665HE Side by Side Refrigerator Logo
Anonymous Posted on Nov 27, 2009
Red light stays on after changing the water filter and running about 2 gallons through it
John Tripp
Level 3:
  • Maytag Master 4,656 Answers
  • Posted on Nov 27, 2009
John Tripp
Maytag Master
Level 3:
Answers
4656
Questions
Helped
1677683
Points
14883
Water Filter Status Indicator
Light (select models)
The Water Filter Status Indicator Light serves as a
reminder to replace the water filter. A green light
indicates that the filter is in good condition. A red light
indicates the filter should be changed. Once light turns
red, it will remain red until function is reset.
To Reset Indicator:
• Press and hold both the Lock and Water
buttons simultaneously for four seconds. The
green filter status indicator light will flash
three times when the function has
successfully reset.
Testimonial: "Great, Thanks"
3 Related Answers
Anonymous
  • Posted on Apr 27, 2011
SOURCE: changed water filter red light stays on
When you hold down lock auto light it turns off all the indicator lights completely. To sufficiently reset the filter to "green" hold down the lock water buttons at the same time for about 15 secs
BRYAN WILLIAMS
  • 8 Answers
  • Posted on Nov 19, 2011
SOURCE: yes bought a new water filter and changed it ran 6
Hi
You have to hold the reset button in for about 15 seconds to reset the light
Bryan
Anonymous
  • 44 Answers
  • Posted on May 27, 2009
you will wither have to push the light switch button 5 times or push and hold reset button or 2 at a time. Look at the display carefully it usually will tell you what you need to do
Frigidaire filter status light will not reset
Check to be sure your water source is on. Low pressure may make the filter sensor think there is a plugged filter.
My freezer
If you have an Ice Maker and/or Water Dispenser with this unit the red light is telling you the water filter is now time to change.
The filter is usually under the front refigerator (behing the bottom cover plate). The filter is about 8" long and 2" wide. Looks kinda like a big white hot dog bun. Remove the filter cover and spin the filter cartridge counter-clockwise and pull it out. A little water will leak but it'll close itself off as soon as it pulls out.
Reinstall the new filter the reverse sequence and run the ice water for 3 minutes or 3 to 5 gallons of water to get all the fatory carbon filter sediment flushed. The light will now turn to green.
Should be all better now.
Filter light will not turn off
Resetting your Refrigerator filter indicator light after changing your water filter
Some people are not aware that after you change your refrigerator water filter, there are two more steps that should be taken to complete the water filter change process.
Step 1:
Reset your water filter indicator light - Most new refrigerators come equiped with an indicator light that notifies you when it is time to change your water filter. This light does not automatically reset when you change your water filter. Here is a list of refrigerator manufacturers and how to reset the indicator light.
GE General Electric Refrigerators - Press and Hold the Reset Button for around 8 Seconds.
Step 2:
Flush a couple of gallons of water through your new filter. Since most refrigerator water filters are made of carbon, some carbon residue is present in the first gallon or two of water. This will leave a bitter taste and residue in your water. If you continue to have these problems after flushing a couple of gallons through the filter, it is possible that you have a defective water filter.
4helpful
Wate Filter Light stays on after filter has been changed.
  • After changing your water filter you have to reset the light for it to go off as it does not reset right away.
  1. Just press and hold the "FIGHT" and "LOCK" buttons until the water filter light flashes. Now the light will be off.
  2. Don't forget to run a couple gallons of water through the new filter to remove any carbon out of the incoming water after installing a new water filter. This is not poisonous by any mean but it can leave a bitter taste in your mouth until the carbon wears off.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
8helpful
2answers
How do i reset the waterfilter light
WATER FILTER CHANGE REMINDER
(Select Models)
For some refrigerator models featuring
water filters, the Water Filter Change
Reminder function monitors the life of the
filter and provides a reminder when it is time
for the filter to be changed.
When the system detects either 12 months
of usage, or the filtering of 416 gallons of
water (whichever comes first), the CHANGE
FILTER indicator light will illuminate. This
indicates that the water filter should be
changed and the light reset.
To reset CHANGE FILTER light: Press and
hold the LIGHT and LOCK pads until the
CHANGE FILTER light blinks (approx. 3
seconds). The control is now reset for 12
months or another 416 gallons.
Note: The Water Filter Reminder will
operate if the filter bypass is in place.
If you have other questions please let me know, Thanks Sea Breeze
After changing the water filter, how do I get the red light on the control panel on the front of the refrigerator to go out?
For some refrigerator models featuring water filters, the Water Filter Change Reminder function monitors the life of the filter and provides a reminder when it is time for the filter to be changed. When the system detects either 12 months of usage, or the filtering of 416 gallons of water (whichever comes first), the change filter indicator light will illuminate. This
indicates that the water filter should be changed and the light reset. To reset Change Filter Light:
Press and hold the LIGHT and LOCK pads until the CHANGE FILTER light blinks (approx. 3 seconds). The control is now reset for 12 months or another 416 gallons.
A more complete manual can be found here=> http://appliance911seabreeze.com/index.html
In left sidebar and last item listed. Go to page 101, Thanks, Sea Breeze
2answers
Changed water filter red light stays on
31helpful
4answers
Afer you change the filter and have run the water for about 1 minute you then hold down the light & lock button together and this should turn the change filter light off.
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
