My Lg Tu500 sys to insert sim card even when its in the phone
My Lg Tu500 sys to insert sim card even when its in there. i tried it in other phones and it says the same thing. but it happened as i was sending a message...could it be broken or can it be repaired?
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. IF Problem not Solved So Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator Enter The Puk code and Yes Enter The pin code and Yes So Puk code Open and Problem will Quickly Solved
Are you sure you did correct instruction how to insert LG Quantum unlock code in your phone? As my knowledge when we do unlocking phone we insert the original sim card not the unaccepted sim card. Try doing that procedure again but this time use orignal sim card when you insert lg unlock code in your phone. Good luck!
hello,the only person to unlock the phone for you freely is your service provider,all you need to do is just to call them and give them your mobile number and imei number.there are no free codes available for it now.
No one can give you free lg tu500 unlock code unless you describe your carrier network and your phone imei number. To generate lg unlock code, carrier information and imei number is needed since one single phone has one unlock code.
i bought my phone throught e-bay too i got optus sim card ask me about secuirty code (sos) i just put 4 zero ( 0000) the phone accepted and un locked try that
Try the SIM in another phone. SIM cards go bad.
If it doesnt work in the other phone it will have to be replaced. I
THis can also be caused if you set up a PIN code and it was entered in wrong too many times and you did not use the right PUK code to unlock it. THis will permanently damage a SIM card.
f it does work in another phone then your phone is no longer able to read SIM cards. Check with the manufacturer for warranty info.
I suggest reducing the size of the SD card to a 512mb and you should have no problem. There have been problems with the 1GB for these phones and I mhave 2 of these phones and they both have 512mb with no problem any larger and they keep giving error messages
