Samsung DVD-Homecinema-Sound-Package  HT-Z110R black Logo
Posted on Nov 27, 2009
Power would not turn on when i turn it on it says hello then protec then power turns off
Anonymous
Level 1:
New Friend:
  • Contributor 9 Answers
  • Posted on Jan 26, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
9
Questions
0
Helped
6901
Points
16
This happens when one of the amplifier chips on the main board is blown. player's main board needs to be repaired or replaced.
Skymedi usb 8gb media write protected
If the write protec switch is in the on position on the card or usb, turn it to off. If it still says its locked, its history!
Need codes for my ProTech television i'm using a Chunghop Universal Remote
Hello
There is only one setup code for Protec TV wit Chunchop remote control. It is [0738].
OK.
5helpful
95 taurus AC no power to compressor. No voltage detected across 4-wire plug at compressor. Fuse under dash OK.
the systemis trying ot protece ieself for 2 reasons you have high pressure or low pressure with what you have told us here that you have low pressure which in turn means that you are low on freon or high/low pressure swich is bad ... which i doubt very seriously but it can happen id go back with the basics and start from there, Ithink that you are low on freon,thanks and I hope that this helps you.
Pioneer tv
you may have problem with convergence IC is shorted and goes in protec mode
Tv wont power up
if you can not turn on TV set with the power button on the TV its not astandby problem as this would by pass the standby. Theres most protec,on a set of this age, top have a poiwer regulator,vertical,horzontal/chcroma problem and is goingto need a trained tech to assist you in this repair. www.afiata.com
4helpful
Manual for the Protec Bytelan KVM/4
The switches are used when cascading more than a single BYTELAN KVM. It specifies the scan rate, and which KVM unit the keyboard and mouse are connected to. For a single KVM, use the default settings. SW1 SW2 Scan Rate ---------------------- ON ON 2 seconds OFF ON 10 seconds ON OFF 20 seconds OFF OFF 40 seconds SW3 NOT USED SW4 ON For KVM unit with KB/mouse OFF For other KVM units w/o KB/mouse, If your power supply isn't adequate, it may cause your KB/mouse problem. It should be 9VDC with at least 500ma. Hope this helps.
2answers
Protec Microsystems
I have one of these and the powerpack is 9 volts 600 mA
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
