JVC HD-61Z886 61" Rear Projection HDTV Logo
Posted on Nov 27, 2009
Blue and red light flashes but no picture - JVC HD-61Z886 61" Rear Projection HDTV
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 05, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
233
Points
I have the exact same problem. Replaced the bulb and ballast and the lights still flash rapidly. Bulb had burst before I ignored the onscreen replace warning.
Does anyone have a clue?
1 Related Answer
Anonymous
  • Posted on Jul 15, 2008
SOURCE: No Picture on screen
THIS PROBLEM HAS HAPPEN TO ME WHEN MY LAMP WAS
ABOUT TO DIE. WHAT I DID WAS UNPLUG THE TV SET FOR
A SHORT WHILE, THEN WHEN PLUGGED AGAIN IT CAME ON BUT THE PICTURE WAS DIM AND THE LAMP ONLY
LAST FOR FEW DAYS AFTERWARDS.
W.J.M.
Xenius 37" lcd blue light just keeps flashing
my 37" xenius tv started losing its picture to a stripe screen then started flashing red blue green .know wont come on at all .wht part do i need to fix it please
57 projection on light flashes but no picture
Look to see when it tries to come on if it flashed bright red, green or blue. This set listed is prone to bad tubes and if acting up will come up and screen may flash--also if not coming on count the blinks on the red light--a specific number of blinks like 6 or 8 is a error code.
1helpful
Hi, We have a 42" hslc10668phz
generally when you get a constant green light all is ok. these different lights indicate different problems within the tv. so the pattern of lights you mention suggests there is a fault of some kind (is there a troubleshooting section in your manual)? either way it needs to be looked at.
SUDDENLY THS MORNING THE BLUE LIGHT ON AND THE RED LIGHT OFF ARE FLASHING ALTERNATELY IE WHEN AERIAL LOCATED TO ON POSITION THE ON LIGHT BLUE FLASHES ALTERNATE RED AND BLUE AND BLUE TOOTH NOT WORKING
I think your car kit has lost its pairing data. Blue and red lights flashing alternately means it is in pairing mode. On your phone (or the device it was paired with), delete the partnership with your car kit, and make it search for new devices again. After a little while, your car kit should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey, or passcode) is requested, enter '0000' (four zeros).
By the way, detailed instructions on how to pair it with your phone (illustrated with pictures) can be found on its user guide; In case yours happens to be missing, you'll still be able to find it here.
Hope you are able to sort your problems out soon.
Please, let me know if I can help you any further.
Regards, Carlos
Sony wega 50 inch television
blue spot is probably light engine. Bad news. Flashing depends on the amount of times your timer power light blinks
W.J.M.
3helpful
Flm-3201
my polaroid model #3200  does'nt come on!  the light goes from red to blue and nothing,the picture stays black with no flashing or flickering
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
