Question about Sony KDF-E42A10 42 in. LCD Television
I try to turn it on but it just blinks on stand by
    New Friend:
When I turn the TV on it green light flashes 3 times then the screen flashes bright white then the TV shuts off.
Posted on Dec 21, 2009
    New Friend:
  • 51 Answers
Probable Lamp. If lamp hasn't bown the red Lamp Lite won't flash but other lamp issues cause stby timer light to continue flashing. If stby red lite is flashing, count the no. of times flashing - could open thermal fuse (6X flashing)
Posted on Dec 03, 2009
6ya staff
SOURCE:
Sony tv will not turn on stand by timer light blinking
Try as suggested to count the blinks to see if it is an error code or not. blinks will be in a sequence with a pause and blink the same number of times over and over.
Apr 29, 2012 | Televison & Video
Tv wont come on and a red light is blinking. I have a Sony Wide screen projection TV model kp-46wt520
Can you unplug the TV for about 15 seconds, and then plug back in and watch the stand-by light. Tell me how many time the stand-by light blinks in regular intervals. If it doesn't blink at all, you need to change a fuse on the g-board. Once this is done run back through the stand-by blink light process, and more troubleshooting can be done if problem isn't already solved. If the stand-by light just keeps blinking with a count over ten just tell me, and I'll look for other possibilities.
Oct 25, 2009 | Sony KP-46WT520 46" Rear Projection...
TV does not turn on. Stand By LED blinks 4 times and pauses and blinks 4 times again Tv will not turn on...when plugged in the red stand by light flashes 4 times...you can hear the tv turn on but a black...
Try to remove the vertical IC sometimes it become Shorted causing the B+ to drop. after removing try to switch on back check the B+ if ok and the LED not blinking then change the vertical IC.
Jun 01, 2009 | Sony KV-27S42 27" TV
On older Sony, sometimes a power surge causes the set to be in shut down mode. Try unplugging for 5 minutes and then plug in and try. This many times will fix.
May 31, 2009 | Sony KV-27S42 27" TV
Sony TV Model Number: KV-27FS100L No Power 1. Stand By LED Blinking Three Blinks No PowerIntermittent. 2. Stand By LED Blinking Three Blinks No Power Intermittent. 3. Stand By LED Blinking Two Blinks No...
Try using another power outlet, if you are using a power distribution board then try plugging the TV directly into a wall socket. If using an extension cord then try with another cord. It also maybe that the factory lead that came with the TV is faulty, any of these problems may be restricting the correct amount of amperage required by the TV unit to operate.
Apr 07, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Stand by timer
stand by timer is blinking green tv will not come on
Aug 05, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Stand by/timer light flashes red television will not turn on
I will need to know the model number of your set to help you as well as if the light blinks a certain number of times in between pauses. Please respond to this same post.
Jul 16, 2008 | Televison & Video
Sony KDF-E42A10 42 in. LCD Television Logo
1,249 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
