GPS Logo
Posted on Nov 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My nuvi 360 speaker does not work. Stopped all of
My nuvi 360 speaker does not work. Stopped all of a sudden without reason.
Anonymous
Level 3:
Brigadier General:
  • Master 4,090 Answers
  • Posted on Nov 27, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
4090
Questions
0
Helped
1184230
Points
12747
Make sure you have not invoked the MUTE function
also check that you select a voice that has TTS next to it Text to Speech
Finally check the volume
Garmin Nuvi 610- working perfectly then sudden crackling and now loss of sound/or at best crackly and intermiitent sound- but map/navigation and on-screen directions fine
Check the audio output setting on the nuvi. There is a possibility that the FM Transmitter setting has been turned on or that the device has been muted.
To check the audio output setting:
  1. Touch the Speaker icon below the Wrench icon.
  2. At the bottom of the screen, touch Audio Output.
  3. Make sure that the Internal Speaker is selected and touch OK (660, 670, 680, and 5000 models only).
  4. Make sure that the MUTE box does not have a check mark in it. If it does, touch the box to clear the selection.
  5. Make sure the volume level is at a reasonable percent level.
1helpful
2answers
Garmin 1200 suddenly stopped loading up....
I am haveing the same problem
[email protected]
Can not seem to find any reason?
1helpful
Voice stopped
Please see this link for more info on this problem:
http://www.sharc.net/gps_audio_repair.htm
- Jim
1helpful
No sound
1helpful
Instructions on replacing nuvi speaker
I have given you the proper information as requested. Good luck!
8helpful
2answers
Garmin nuvi 360 speaker not working
I fixed my wife's with a speaker from Digikey, part number 102-1564-NE (2 watt speaker, 8 ohms). If you have the guts to take it apart, then it's not too tough. I used a 0.020" thick plastic card (a credit card is 0.030 and is a little to thick) to separate the cover, a very small torx and phillips screw driver, and a soldering iron.
Jun 14, 2008 • GPS
Audio problem
Steps:
1. Make sure battery is charged. Go to Step #2.
2. Press reset button and try it again. If still bad, go to step #3.
3. Try using headphones.
By using the headphones, you are bypassing the internal speakers, which might have failed. If the sound is still missing, the mostly like problem is a defective audio output stage on the motherboard. Since this unit uses surface mount technology it will have to be sent back to the manufacturer for repair.
Audio problems
Steps:
If the sound works with the headphones, the speakers have failed. I have seen several postings of speakers failing in the Nuvi 350.
In either case, you will need to send the unit back for repair. Be sure to have your serial number handy. Register it online https://my.garmin.com/mygarmin/marketing/register.htm
if you haven't already done so.
Hours:
Monday - Friday
8 a.m. - 7 p.m.
Central time (closed holidays)
1-800-800-1020 (U.S.)
1-866-429-9296 (Canada) or (913) 397-8200
Good Luck,
- Jim
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
