West Bend (58036) 36-Cup Coffee Maker Logo
Posted on Nov 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How much coffee grounds for a 22 cup west bend coffee maker?
ellenskitche
Level 2:
Sniper:
  • Expert 62 Answers
  • Posted on Nov 27, 2009
ellenskitche
Expert
Level 2:
Sniper:
Answers
62
Questions
0
Helped
33578
Points
201
We use 2 1/4 cups for a full 36 cups. A fraction under 1 1/2 cups is good for 22 cups.
For a 30 cup pot how much coffee do you put in
According to West Bend...30 cups = 1 ¾ cups ground coffee; add more if you prefer it stronger.
How much coffee do you put in for 30 cups
How much coffee does it take to make 55 cups?
According to West Bend...55 cups = 3 ½ cups ground coffee, add more if you prefer stronger coffee.
How to make stronger coffee
West Bend recommends 2 cups of (medium coarse) ground coffee for 36 cups of coffee. It also states that theses measurements are for mild coffee. Add another 1/4 - 1/2 cup for stronger coffee. Keep adding more until it meets your liking. Here's the link to the manual for model #58036. http://www.manualslib.com/manual/337763/West-Bend-58030.html#manual
How many coffee scoops do i use for 30 cups and 36 cups
The Instruction Manual for your coffee maker can be found here:
http://www.westbend.com/supportdata/L5590A_Coffeemakers_ALL.pdf
Instructions include the following:
Water Level Amount of Ground Coffee
42 Cups 2 ½ Cups
36 Cups 2 Cups
30 Cups 1 ¾ Cups
28 Cups 1 2/3 Cups
24 Cups 1 ½ Cups
22 Cups 1 ½ Cups
18 Cups 1 ¼ Cups
12 Cups 1 Cup
1helpful
How much ground coffee should I add to my West Bend 58030 Coffee Maker to make 30 cups of coffee?
For 30 cups of coffee, use 1 ¾ Cups of ground coffee for mild coffee. If you like a stronger brew, add more ground coffee.
Retrevo has the manual for the West Bend 58030 here: http://www.retrevo.com/support/West-Bend-58030-Coffee-Makers-manual/id/4210ag322/t/2/ . You will need to enter a code to download the pdf.
I hope this helps.
1helpful
Where can I replacement filters for a 100 cup West Bend coffee maker?
The West Bend Large Capacity Coffemakers do not use replacement filters. The manual for the West Bend 33600 Large Coffee Urn is available here:
http://www.westbend.com/supportdata/L5613B_LargeCapacityUrns-All.pdf
Use an electric perk or regular grind coffee in the percolator basket rather than a 'drip' or finely ground coffee that would require a filter.
If you require a new basket, please see the West Bend on-line replacement part site here:
http://www.westbend.com/catalog.cfm?dest=itempg&itemid=946&secid=87&linkon=subcategory&linkid=125
Coffee to water
The Instruction Manual for the West Bend Coffeemaker can be found here:
See page 4 for amount of coffee to use.
42 Cups 2 ½ Cups
36 Cups 2 Cups
30 Cups 1 ¾ Cups
28 Cups 1 2/3 Cups
24 Cups 1 ½ Cups
22 Cups 1 ½ Cups
18 Cups 1 ¼ Cups
12 Cups 1 Cup
Use electric perk grind coffeeror coofee ground for all coffeemakers. Do not use drip or finely ground coffee.
3helpful
I lost my instructions and need to know the coffee to water ratios
Water level: Amount of coffee:
42 cups 2 1/2 cups
36 cups 2 cups
30 cups 1 3/4 cups
24 cups 1 1/2 cups
22 cups 1 1/2 cups
18 cups 1 1/4 cups
12 cups 1 cup
I have a 22 cup coffee maker and the stem got lost. the part that hold the coffee basket in place
Assuming you have a model 58602, the only 22-cup urn listed on West Bend's parts site, the news isn't good. The parts page for that model says the stem is no longer available. Checking a few other parts links all turn up the same answer. You might try checking locally at thrift stores or on Craig's list to see if anybody has one available.
Sorry I can't do more, but thanks for using Fixya!
Top West Bend Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Kolbrun...
Are you a West Bend Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
