The heater element is in the bottom of this cooker, which creates the challenge. You could switch to a Nesco, which has the element around the sides (joke). If you preheat the roaster for at least 20 minutes before putting the pan in, that helps. Then of course, a layer of foil in the bottom, and a heavy spray of the griil type Pam (works better at higher heats) will help; and you can drop the temp 25 degrees and add 30-45 minutes to the cook time.
