Panasonic Lumix DMC-TZ3 Digital Camera Logo
Posted on Nov 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I want to have the date show on my digital prints. I have set both the time clock and world clock, but date will not appear on screen after taking picture, or on a printed picture.
Anonymous
Level 3:
Guru:
  • Master 1,738 Answers
  • Posted on Nov 26, 2009
Anonymous
Master
Level 3:
Guru:
Answers
1738
Questions
Helped
470893
Points
4963
You have to go through the main menus and select time and date. and tell it only date.
Delete international clock from galaxy 4
About 1,620,000 results (0.50 seconds) Search Results
    Samsung Galaxy S4: How to Create And Delete Clocks in ...
    www.itjungles.com/samsung-galaxy-s4-how-to-create-and-delete-clocks-...
    Due to business trips and different time zones/ working hours, you may sometimes need to use World clock to check your partners time zones to send emails and ...
    World clock constantly appearing when making calls - Android ...
    forums.androidcentral.com > ... > Verizon Galaxy Note 2
    Jun 28, 2013 - Recently, when making a call, the world clock appears and requires a bunch of clicks to close. ..... I have a Samsung Galaxy S4 with Verizon. LG G3 - world clock widget that will show two time zones ...
    Aug 9, 2014
    How to remove alarms from the clock?
    Dec 6, 2013
    Samsung Galaxy S4 Android 4.3 Update Issues - Page 3
    Oct 28, 2013
    How to remove clock and weather off lock screen?
    Oct 26, 2013
    More results from forums.androidcentral.com
    How to use the World Clock Android app - Time and Date
I don`t know how to change the date and time of my sony dsc-t200
Hello there. You can do it this way:
1 Select (Clock Settings) from (Settings) on the HOME screen. 2 Touch [Clock Settings]. 3 Touch the desired date display format, then touch [t]. The clock settings screen appears. 4 Touch each item, then set its numeric value by touching v/V. 5 Touch [OK]. To cancel the clock setting Touch [Cancel] or [BACK] in step 5.
Sincerely, Steve TM
1helpful
2answers
How do i change the time and date on my Sansung GT-B5722, it is set on the 01 01 2009?
you may wanna try this:
Create and view world clocks Learn to view the time in another region and set world clocks to appear on your display.
Create a world clock
1. In Menu mode, select World clock.
2. Select Add.
3. Scroll left or right to a time zone.
4. To set daylight saving time, select 1.htm92.gif.
5. Select Add to create your world clock.
6. To add more world clocks, repeat steps 2-5 above.
Add a world clock to your display
With the dual clock widget, you can view clocks with two different time zones on your display.
After you have created world clocks,
2. Select the world clock you want to add and select More → Set as 2nd clock.
2answers
My camera shows that the date and time are set up but date does not print on picture when developed. it's a new camera and I just developed my first set of prints and there is no date on any of them. ...
On digital cameras, the data is stored with the filename. Check the back of your prints to see if the dates were not printed there. Most companies do put at least the date information on the back of the prints as well as any other metadata stored with the file produced by the digital camera. Unlike film cameras, which could only record the date by actually putting it on the picture, digital pictures contain metadata that can include things such as people tags, location tags (geotagging), etc. depending upon the capabilities of your camera. The date and time is always stored along with the filename on all digital cameras. If the company that printed your pictures did not include the date on the back of the picture, ask them if they can do it or find another source to print your pictures that can.
If this did not address your issue, please reply with any amplifying information so that I may more accurately address your issue.
I hope this helped!
Clock is flashing....input the correct date on camera so when i print photos the correct date is showing...how do i put in the correct date?
Press the MENU button to bring up the menu. Select the CSM menu, then select "World time". Select "Date". Use left/right to move between the fields, up/down to change the value of the current field. Press OK when done.
I have a Panasonic Lumix DMC-FX520 and the date stamp wont appear on printed photos. The date shows when I take the photo,how do I get the datestamp to show up afterwards
Normally in the menu settings the options are entered so as to stamp the date in. So open menu settings and check on clock and date settings. check for links to date stamping in the menu and activate.
Sep 24, 2010 • Cameras
1helpful
Have just purchased a Lumix dmc FH20 and set the clock. how can I take photographs without the time and date recorded on the photo. Thanks
Are you sure the time and date are actually printing on the photo or just showing up on the lcd screen?
Jun 30, 2010 • Cameras
How do I get the date and time to show up on either printed pictures or on my downloads onto my home computer? I have set the date and time but it doesn't show up on anything, even my cameras own screen.
The date and time plus a lot more information is stored with each picture as "metadata". It can be retrieved in most photo editing programs. After downloading to your computer, if you just right-click on a picture file, the date and time will appear.
I CANT GET THE DATE TO DISPLAY ON STYLUS 7010
there is a display button at the bottom right of the back of the camera. its the very bottom rocker buttons. it says DISP/? or/(and the trash symbol). knowing this go to look at your pictures (using the "play" symbol) and click DISP. the time and date should appear now.
5helpful
2answers
Settiongs for Weather Data World Clock
Citizen Weather Data Clock Settings.
To set time press and hold for 5sec "set" button
Use advance to add days, years, hours seconds.
Press SET to hold.
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
