Kodak EASYSHARE 5100 All-In-One Printer Logo
Posted on Nov 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
CAn I print only odd numbered pages - Kodak EASYSHARE 5100 All-In-One Printer
Anonymous
Level 1:
New Friend:
  • Contributor 25 Answers
  • Posted on Nov 30, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
25
Questions
0
Helped
14066
Points
73
Yes, you can print only odd-numbered pages for example from microsoft word -- it has a feature visible when you select file -> print, see "print: all pages in range" and change that to "print: odd pages" (it`s a drop down list).
Good luck !
Anonymous
Level 2:
  • Expert 295 Answers
  • Posted on Nov 27, 2009
Anonymous
Expert
Level 2:
Answers
295
Questions
Helped
108786
Points
501
No,this is not a feature of the Kodak all in one printer.You can still manually select the page number in printer settings while printing from ur application..
1helpful
How to take back to back printing in canon LBP 2900
Here are the steps in this process:
  1. Go to File menu and then select Print.
  2. Print dialog box will come up. ...
  3. Click OK to print all the pages in document that have odd numbers.
  4. Once printing of odd numbered pages is done, flip the stack of printed pages and put them back in tray.
http://techwelkin.com/print-two-sides-paper-without-duplex-printer
Can i set the Brother HL-2140 to print double sided. I cannot find it ?
The Brother HL-2140 does not include duplex printing. The only option for double sided printing with this model is to print odd numbered pages, then manually replace the paper into the tray and print the even numbered pages in a second set.
Regards,
Dan
IT Professional
All I want to do is to be able to print off the whole manual for my 'Epsom DX3800 All-in-one printer'. I have already contacted Epsom several times concerning this and have not receive the help that I...
if you want print both side you need duplex printer. but you can print from normal printer also. for this you have to select odd option in printer window then print. by this way printer will print odd page numbers 1,3,5,7... only. after that flip printed pages and select even option in printer window. this will print even page numbers 2,4,6,7... by this way you can print papers both sides.
2answers
I have printed all odd # pages from a document, but my HP Laserjet 4 won't feed these pages back through to print on the blank side with even # pages. I've tried to keep the front (feeding edge) of papers...
You need to try a thicker paper, Heavier stock to double print the page. Slightly more expensive. Recycled paper typically will not work for this type of function. I had this same problem and found this was the only solution.
2answers
Gray background only on odd number pages
your cartridge is defective.. just replaced a new one.
Double sided printing Pixma MP520
here's how:
print double sided pages
1. Set your computer software for double sided printing if you have a printer that is compatible. Double sided printers are generally professional style machines, and most offices, schools and libraries will have them. On a PC, go to the drop down "File" menu and select "Double Sided Printing" under the "Preferences" or "Properties" window and print. If you have a MAC, click "Copies and Pages" under the "File" menu, select "Layout" and then click on "Long-Edged Binding" and print.
2.Print double sided with your standard home printer, again, by setting your PC writing software. When you are ready to print, click on the drop down "File" menu and select "Print." From the "Print" window select "odd pages only," or "even pages only."
3.Set your odd and even pages a bit differently if you are working with MAC writing software. Select "Print" from the drop down "File" menu and click on the arrow to drop the "Copies & Pages" menu. Under the "Copies & Pages" menu, select "Paper Handling" and then click on "Odd Numbered Pages" or "Even Numbered Pages."
4.Select "Odd Pages Only" or "Odd Numbered Pages" and then print as usual. It is a good idea to mark the top of your first page with a pencil so that you know the direction and side of the page your printer prints. Use the mark to determine how to turn your pages and place them back in the printer. Select "Even Pages Only" or "Even Numbered Pages" and print again. $('.Article .Steps .Image').each(function(i,e){ e = $(e); e.find('img').error(function(){ $(this).unbind(); e.remove(); }); });
Print Odd or even pages only
There is no option in the printer to chose eve or odd pages bout if you print under windows environment you can do that from the able cation example if you use Microsoft world go to file chose printer then chose eve or odd from print comp box
Top Kodak Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
