I have had the same problem, and can't fix it at the refrigerator. You need an presure reglator or bladder on your hot water heater. when you have to much pressure it usually starts causeing problems at the hot water heater with leaks and works its way down in other areas of the house. We put a regulator at our water meter at first and it did not help.. if it is leaking at your fidge, you may want to check other appliances.
Hope this helps
SOURCE: Water leaking from left side ice/water dispenser
If you describe a constant flow of water from the ice maker then the solenoid valve is either leaking by when it's upposed to be off or the motor module is stuck in the "fill" position. If it was stuck in fill you would be getting a LOT of water all the time so if you only have a trickle then the solenoid valve may be letting water leak by it. The diagram here shows the parts for a better idea of what you may need to look at (and where it's at). http://www.partselect.com/Schematics/Frigidaire/SZGBPCQH.gif
SOURCE: My Frigidaire refrigerator water dispenser
I found that I have the same problem this morning. Has anyone found out how to correct it or did you have to call for service? Did they fix it?
SOURCE: icemaker
Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
Let me know if this helps.
SOURCE: Water is not going into icemaker, I've replaced
I have a maytag side by side with water in the door, the cold water works but the icemaker doesn't. No water flow into the icemaker, it doesn't appear to be iced up. Can not tell if the selenoid works.
SOURCE: water leaks about once every two days from our
there is a leak after the water supply valve so when the icemaker calls for water you geta leak
