Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
Anonymous Posted on Nov 25, 2009
SONY KV-32FS100 TV DOSENT COME ON ONLY FLASHING RED LIGHT ..5 FLASHES AND STOP ,,THEN REPEATS
Anonymous
Level 2:
Scholar:
  • Expert 63 Answers
  • Posted on Nov 25, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
63
Questions
0
Helped
11983
Points
195
This is the error code for what is termed IK which controls the video to the pic. tube essentially. The most common failure I've seen is the video output i.c. on the crt board also known as the C Board. This is IC702 and is available, the generic number is on the i.c. and can be purchased at a place like mcmelectronics.com . Also someone may have turned up the screen level control located on the flyback transformer. If this is too high the set detects the excess beam current and shuts the set down. If you are not into tackling a problem like this yourself you will need a tech to check it out and give you an estimate. The repair cost would be mostly labor for the diagnosis and part replacement. I don't believe you would be looking at much for parts themselves.
Testimonial: "a perfect solution i will replace the part ,,i know how to repair the tv,, i have the equipment,,to do it i just diddnt know the code"
Little red light on front flashes and no picture. Help! Thanks...
The standby light should be blinking in a repeated pattern. Pleawe count the blinks and report that number here. That count indicates the circuit that is having a problem. Also, please confirm that the set is model number KV-32FS100.
Thanks,
Dan
Sony Trinitron TV. No picture; red standby/timer light flashes.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
32" Sony Trinton Wega
Count the flashes and verify that the model is KV-32FS100. The flash count will indicate the circuit in which the problem was detected.
Thanks,
Dan
Sony FD Trinitron Wega model KV-34BR800
Sony Wega Triniton KV-32FS100 TV
For the last week my TV has been going to a black screen for 10 seconds or so then the picture returns. It has been continual. Last night it stopped going to black screen, but now the standby light flashes 5 consecutive times and the color went haywire. A lot of red and everything that is suppose to be black is green.
I did a soft and hard reset with no success. What's wrong and is it worth fixing? Bought new in November 2002.
1helpful
2answers
Sony tv wont start up???
The flashing should be a repeated number of blinks. Please post that count as that will indicate the circuit in which the set detected a problem. The set is in protective shutdown. Using hte blink count, we can determine the possible problem and solutions.
Dan
KV-32FS16
5 times flash light shows that your TV has white balance error. If you have basic knowledge of electronics, then adjust G2 voltage of tv. hope problem will be solved.
Sony FD Trinitron WEGA KV-36XBR800 36" TV
I get a black screen after power on...then a bright white light in the middle of the screen.Then the red light flashing and turns it self off.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
