Question about HP OfficeJet 7110 All-In-One Thermal Printer
Lights Flashing My 7110 printer is not working, all of the lights are flashing, unplugged and still not working. All I get now are flashing lights.
  • 4 more comments
  • Anonymous Jan 16, 2008
    I tried what you suggested, however, to no avail. I tried this numerous times and still only get flashing lights! I have been told it is a hardware problem, sad to hear a printer this old is worth nothing!
  • madbackers Mar 15, 2008
    Lights flashing, supply expired is the comment in the window. Have tried 3 new ink cartridges to no avail. HP printers seem to be full of problems.
  • Masala Mar 16, 2008
    When I try to print anything, the lights flash and it tells me to power off/on the unit. It does this everytime. I have disconnected the power for 5 mins and also tried reinstalling the drivers/software on my computer. Nothing has worked so-far.
  • jaydoe2004 May 06, 2008
    I recently encoutered a problem with my printer. When turning it on it reads turn power off and on. Its constantly saying self test. If anyone can help me out with this issue. Please let me know.
  • Anonymous Sep 03, 2008
    same problem, when try to print it begins, then lights flash and printing stops.
  • mamec Sep 06, 2008
    I can copy whatever I want and have full use of the enlarge/reduce feature, everything working fine except when I prompt it to print a document through the computer. I have uninstalled the software and unplugged the usb and power cords then reinstalled the software, plugged in the usb, then powered up and got one printing, then the lights began flashing again and so I turned it off and then on....it won't print again and I'm tired of trying the same things over and over again. I did get some sort of error message like "Startprinterprompt missing" when I tried to print in Notepad. Will I be unhappy with a new color laser printer when printing greeting cards?
My printer did the same thing.  It turned out to be the scanner table cable. the one that you can see throught the glass.  When you follow it to the connection, where the ink carrage is,  and under the silver cover you might find the flat cable disconnected or loose.  I plugged it back and it stopped.  Now I have to tackle the ink tray problem. Hope this helps. Toby
Posted on Jan 14, 2008
  • jorgesequera Sep 27, 2010
    Three years later, I solved my problems with this suggestion.... thanks a lots.... (sep2010)
SOURCE:
Why does exclamation point orange light flashing on HP Officejet 7110?
The lights on the front of the HP product can be on, off, or blinking (flashing), depending on the status of the product. The lights indicate product status and are useful for diagnosing printing problems.
For more read... HP Support document and HP Tech Support .
Thanks,
Jun 27, 2014 | HP OfficeJet Office Equipment & Supplies
ALL FLASHING LIGHTS
hi there.
if all lights are flashing, turn off the printer and unplug it from the power source, wait for about 10minutes. while its off, check for obstruction or paper jam inside the printer, take it out, if theres nothing in there, good, turn it on, if still all lights are flashing,
that means, the printer is broken, call epson to get a replacement printer if the product is still 1 yr. from the date of purchase, if it is more than a year, most probably, thats out of warranty,
Feb 17, 2010 | Epson Stylus Pro 9800 InkJet Printer
All the lights keep flashing --won't print!
I removed the black ink cartridge that was REFILLED at a popular retail outfit and replaced it with a remanufactured one I bought on the web. As soon as I closed the lid, the flashing stopped and it has been working GREAT ever since. Many postings had already recommended the changing to a "new cartridge" to remedy this flashing lights and "pen failure."
Jan 14, 2010 | HP Photosmart 2410 All-In-One InkJet...
All of the lights are flashing and will not print
please hold on the start buttom for 1 min to check it works back or not.
if still not working, please unplug the cable and rest for 5 min then plug it back on.
May 28, 2009 | Brother HL-2040 Laser Printer
Turn on, all lights flashing, can't turn off unless i unplug printer
It's highly likely that your printer has reached the "service required" point but I couldn't be 100% sure.
I'd recommend downloading the SSC utility from SSCLG, get that installed and then follow the instructions for configuring to your printer model and resetting the protection and overflow counters.
If that works you'll then want to be thinking about cleaning the waste ink pads or installing an external waste kit.
If it doesn't work you have bigger problems and need to describe the flashing patterns and any other symptoms in detail.
Hope that helps.
Martin
May 19, 2009 | Epson Stylus Color 860 InkJet Printer
All three lights are flashing on my HP Deskjet 6127. I tried unplugging it from the power source and then plugging it back in. When I try to turn it on all three lights flash and it won't turn off with out...
Hi
The HP Deskjet 6127 has four buttons and three lights on the front panel
Flashing lights on the printer indicate the status of the printer
When all the lights are flashing, the printer may need to be restarted
try this 1st press the power button to turn off the printer, and then press the power button to it back on very quickly.
2nd press the power button to turn off the printer and hold it down.
Good luck
Jan 29, 2009 | HP DeskJet 6127 InkJet Printer
Printer has all lights flashing
Remove all ink cartridges. Then unplug your printer and plug it in again
If you need further help, I’m available over the phone at https://www.6ya.com/expert/alex_22751bbefa74c3d0
Jun 07, 2017 | HP DeskJet 5150 InkJet Printer
Epson C48 red and green lights flashing alternately
Only Solution is Re-burn printer firmware.
Mahesh DG, Pune
Sep 08, 2008 | Epson Stylus Photo 1280 InkJet Printer
HP OfficeJet 7110 All-In-One Thermal Printer Logo
610 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
