Question about Wolf Range 18 in. SPR-100 Gas Cooktop
My ignition will not stop clicking - Wolf Range 18 in. SPR-100 Gas Cooktop
  • 241 Answers
Hi friend,
There are a few things to check for. Make sure the electrode ( the small metal piece that the spark comes off from ) is clean and the holes in the burner are clean, use a pin or paper clip to clean out the burner holes and NOT a tooth pick as these can break off and make things worse. Example of a burner. The next thing to check for are the ignition switches under the surface control knobs, the switches can twist and break and keep the spark module on and the spark keeps "clicking" even when the burner is light. If every thing looks good, you may have a bad spark module, replace it. Sometimes cleaning can get moisture into the surface switches, try drying them with an hair dryer to see of this will help.
it sounds like it is the spark module that's making the clicking noise. normally there are 4-6 wires that connect to it , and if you are not comfortable making the repair yourself then I would call an appliance repair company.The part should cost 30-50 $ Good luck
hope this helps u
please rate me.......................
thank u for using fixya
regards
sivaranjini
Posted on Nov 25, 2009
6ya staff
SOURCE:
Gas Kleenmaid cook top, one igniter continues to
the switch for the ignitor is stuck. might need to free the switch, of
> call the repair man.
Oct 20, 2013 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Sparker turned on by itself and would not stop
Hi rlimaye1,
The ignition switches probably got wet.
Please follow my below Tip on how to fix it:
GAS STOVE CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Sep 11, 2011 | Maytag MGC5430BDS Gas Cooktop
Same one - ignition click will not stop. Is there a solution?
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
wwttw
Sep 25, 2009 | GE 30 in. Profile JGP933 Gas Cooktop
Ignition is clicking all the time, whether the gas is lit or not.
The clicking is the igniter. If it is clicking and not lighting, then you may have to purchase an igniter kit and replace it. the relays can go bad, or igniter fails.
Sep 04, 2009 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Clicking sound from GE gas stove igniters
u most likely have a gas supply valve problem, the clicking will continue until that is fixed.
Jul 22, 2009 | GE Profile JGP636 Gas Cooktop
Dcs igniters
clean the knob control by using vaccium,pull the knobs then clean it.make sure how to remove the knob,same position to returrn the knob
Jun 30, 2009 | GE Profile JGP636 Gas Cooktop
Igniter clicking when all four knobs in off position after water spill
It is possible that once the unit dries out the clicking will stop. If it doesn't, you will need to call someone to have the problem addressed. You will need a spark module and or an ignition switch(s).
Oct 28, 2008 | GE 30 in. JGP336 Gas Cooktop
Burners ignite simultaneously (clicking)
When you set a burner to light, all burners spark. This is normal. Move knob back off the spark position as soon as burner lights. All sparking will stop.
Sep 04, 2008 | DCS 48 in. CP486GDSS / CP486GDSSL /...
All five ignitions clicking rapidly
yes is safe you probably got the ignighters switch's wet if one is wet will cause all to fire after awhile they dry and return to normal
Jan 10, 2008 | Cooktops
1 burner wont stop clicking on miele cooktop km 344
We have an older Thermador Gas Cooktop type range. It was working fine until the cleaning crew came in, then all the burner igniters were clicking when turning on a single burner. I solved the problem by cleaning off the igniters. I first of course unplugged the power. Then I took a small wire telcom pic tool to scrape the white and brown deposits from the sides of the igniters. You could probably use something else similiar to do the scraping. I noticed a shiny surface underneath. I then went ahead and scraped and brushed clean the mating surface where the spark travels. I then vacuumed up the mess. My burners all worked great after this. Hope this helps!
May 06, 2007 | Miele 36 in. KM342 Gas Cooktop
Wolf Range 18 in. SPR-100 Gas Cooktop Logo
1,179 people viewed this question
Top Wolf Range Cooktops Experts
Paul Carew
William Erickson
DocZachary
DocZachary
Are you a Wolf Range Cooktop Expert? Answer questions, earn points and help others
