Be sure to plug into the "green" socket on the front of the computer, not the "pink" (microphone) or "blue" (headphone output from iPod) socket.
Try the speakers in the "green" socket on the back of the computer, to ensure that the speakers work, and the volume control is "high", and that you have not "muted" your speakers.
Some motherboards have a small "jumper" to enable/disable the front audio-output sockets.
Try the speakers when connected to the headphone-output from your iPod, to confirm that they work -- they could be quite quiet.
Instructions
1. Connect the black plug of the rear right speaker into the black plug on the subwoofer.
2. Connect the yellow plug on the rear left speaker into the yellow input on the subwoofer.
3. Connect the red plug of the front center speaker into the red input on the subwoofer.
4. Connect the white plug of the front left speaker into the white input on the subwoofer.
5. Connect the d-sub connector plug from the front right speaker into the d-plug connector on the subwoofer.
6. Connect the green, black and orange input to the matching plugs on your computer. If you have a four-channel sound card, connect the green plug from the input audio cable to the front plug of the card and the black plug to the rear plug. Do not connect the orange input. If you are using a two-channel sound card, connect the green plug from the input audio cable to the "Line Out" jack on the sound card. Do not connect the green and orange plug.
7. Plug the subwoofer power chord into the electrical power outlet.
8. Place your subwoofer on ground around your computer desk. Position the front center speaker on top of your computer monitor.
9. Place the left and right front speakers on the sides of the monitor. Position the left and right rear speakers behind you, making sure they are pointing toward the front left and right speakers.
10. needs to support 5.1 surround. Normally, more than three sockets for sound indicates that it does. Then you need to use the software that comes with the sound hardware to configure it for 5.1 - Default will be 2.1 or just 2.
Check the control panel out. This is a lot easier under Windows 7.- Here you can access what you need via the speaker icon on the system tray (right click)
There is NO problem with your OS or hardware, this is pretty standard...
hope this will help you solve your problem.
it still wont work when i go to my volume controls it says theres no active mixer devices avalible and i dont no what to download for an active mixer device and i dont no what and active mixer device is and i dont no how to download an active mixer device bear with me here i no almost nothin on computers
and there not quiet i had my frineds ipod hooked up to them and they were pumping music no problem
