Question about Buck Toyota Rav4 2003 Stereo/radio Wire/wiring Harness Plug
Where can i find a wiring diagram for toyota rav 4 2003?
  • 15,935 Answers
RADIO 12V|blue/yellow |+ |radio |
| RADIO GROUND|brown |- |radio |
| RADIO SWITCH|gray |+ |radio |
| RADIO ILLUMINATE|green |+ |radio |
| LF SPEAKER|pink - purple | |radio |
| RF SPEAKER|lt. green - blue | |radio |
| LR SPEAKER|black - yellow | |radio |
| RR SPEAKER|red - white | |radio |
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Nov 25, 2009
SOURCE:
2011 Rav 4 tailgate won't unlock?
There's this website www.reliable-store.com
They have
books on ALL vehicles.
it covers wiring diagrams, electrical diagrams,
fuse diagram, torque specs, PCV, error codes, fault codes, service info, repair info, parts info, owner's/service/repair/parts/maintenance manuals etc everything totally..
I have 1987 toyota 4runner model and I keep servicing and when needed repair it on my own. worth it !!!
Mar 17, 2018 | Toyota RAV4 Cars & Trucks
Stereo wiring diagram 1997 toyota Rav
1997 Toyota RAV4 Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green/White
Left Front Speaker Positive Wire (+): Purple
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Dec 27, 2016 | Toyota Cars & Trucks
NEED TO KNOW WERE # 3 FUEL INJECTOR IS LOCATED ON 1999 TOYOTA RAV 4
Hi there:
Check and follow #3 sparkplug wire, acording with this diagram... 1999 Toyota RAV4 4 2.0 liter DOHC L4 (3S-FE)
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Nov 10, 2012 | Cars & Trucks
I am looking for belt routing diagram for 2003 rav 4
http://www.2carpros.com/diagrams/toyota/rav4/2003
Mar 06, 2011 | 2003 Toyota RAV4
I just bought Alpine car stereo CDE-100EUB but I'm having trouble connecting it to my old car toyota Rav 4 2004 model because the wire harness are different. also the alpine wires are more in numbers than...
Please let me know if you have any questions, and thanks for using FixYa.
2004 Toyota RAV4 Car Stereo Radio Wiring Diagram Alpine wire color
Radio Constant 12V+ Wire: Blue/Yellow yellow
Radio Ignition Switched 12V+ Wire: Gray red
Radio Ground Wire: Brown black
Radio Illumination Dimmer Wire: Green none
Radio Antenna Trigger Wire: N/A blue
Radio Amplifier Trigger Wire: N/A blue/white
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Wire (+): Pink white
Left Front Speaker Wire (-): Purple white/black
Right Front Speaker Wire (+): Light Green gray
Right Front Speaker Wire (-): Blue gray/black
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Wire (+): Black green
Left Rear Speaker Wire (-): Yellow green/black
Right Rear Speaker Wire (+): Red violet
Right Rear Speaker Wire (-): White violet/black
Jan 02, 2011 | Alpine Car Audio & Video
I need help getting the serpentine belt on my 2004 Rav 4
SOMETIMES THE DIAGRAM IS ON THE UNDERSIDE OF THE HOOD. OR ON THE WHEEL WELLS INSIDE THE ENGINE COMPARTMENT. CHECK UNDER THE HOOD ANYWHERE A STICKER COULD BE. IT MIGHT ALSO BE IN THE OWNERS MANUAL.
Feb 23, 2010 | 1999 Toyota RAV4
1998 toyota rav 4. Right side low beam headlight doesn't work. Hi beam on that side does. Checked fuses, they appear OK, and tried 2 other headlights. Left side hi and low working fine.
sounds like there is a broken wire. the only advise i can give you is to follow the hot wire for that light untill you find the break in the wire.
Dec 25, 2009 | 1998 Toyota RAV4
Toyota rav 4
I can get you a diagram on monday but it goes from the alternator to the power steering pump then around the tensioner pulley then around the crank pulley then to the a/c compressor then pull on the tensioner to give you some slack and slip it on the waterpump.I hope that helps.Let me know if you still need the diagram
Nov 30, 2008 | 2004 Toyota RAV4
Buck Toyota Rav4 2003 Stereo/radio Wire/wiring Harness Plug Logo
2,837 people viewed this question
Top Buck Car Audio & Video Experts
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
handygirl911
handygirl911
Are you a Buck Car Audio and Video Expert? Answer questions, earn points and help others
