Many times we face this problem when we forget or lost Windows password or somebody had changed the password of our system. In such a situation either we have to install windows again or find a solution to reset the password so that we can log into Windows easily. In this post, I will show you how you can reset the password on Windows easily with the help of your Flash Drive without reformatting or reinstalling your system. In this post I will use a Flash Drive of 2 GB. Below are the steps to reset Windows password using bootable USB Flash Drive.
Step1. Download a free demo version of Windows Password Key 8.0
http://www.lostwindowspassword.com/downloads/Windows_Password_Key_Demo.exe
Step2. Run the downloaded file to install Windows Password Key 8.0. You can install Windows Password Key 8.0 on any PC you have access to.
Step3.Windows Start menu - From your Microsoft Windows Start Programs menu, select Windows Password Key | Windows Password Key 8.0.exe. . Windows Password Key 8.0 will be launched automatically.
Step4. Create a bootable USB Flash Drive
4.1 You can click ''Browse'' to browse Windows Password Key 8.0 image file. The file is usually located as the default.
4.2 Select ''USB Flash Drive'' and insert your USB into a USB port on the computer, specify the USB Flash Drive from the pull-down list.
4.3 Click ''burn'' button.
4.4 Windows Password Key extracts the ISO image and copies the necessary files on a USB Flash Drive
4.4: Put in your newly created USB Flash Drive and remove your Windows password:
1. Insert newly created USB Flash Drive and reboot your computer.
2. It's necessary to change your computer's setup to make it boot from the USB Flash Drive.
a. pres 'F2' or 'Delete' or ''F10'' to enter your BIOS setup.
b. Looking for a tab or menu relating to booting in the BIOS setup software's opening screen. In this example, it's simply called ''BOOT,'' and can be accessed by using the tab and/or arrow keys to highlight the word ''BOOT'' on the menu bar. Once there, hit enter, and you'll see a submenu that's specific to how the PC boots.
c. Using the tab and/or arrow keys,select ''Hard Disk Drives'', and hit ''Enter''.
d. Select the ''1st Drive'', hit ''Enter''.
e. Select the ''USB: your USB brand'', in the example it is ''USB: Kingston DTG(2G)'', and hit ''Enter'' to Set the USB Flash drive as the first bootable option.
f. When you're done with the BIOS setup program, using the tab and/or arrow keys to navigate to the EXIT menu, select the option for saving the changes you just made, and then reboot. (In many BIOSes, a special key--often the F10 key--will save, exit, and reboot in one step.) . When your computer restarts, it will boot from the USB flash drive.
3. When the USB Flash Drive boots, you'll see Windows Password Key 8.0 initializing (see screen shot below). If so, you can continue to the next step.
4. Choose the Windows installation to be processed:
5. Choose the user whose password you want to reset by typing it's number and pressing 'ENTER'.
6. Type 'y' followed by 'ENTER' to reset the password.
7. After you confirm the resetting of the password. Windows Password Key 8.0 asks: 'Reset password for another account? (y/n)'. Type 'y' to reset password for another account, or 'n' if you are finished and want to exit. Remove the Windows Password Key 8.0 bootable CD/DVD and restart your PC. Now you are able to log into your computer without a password!
For more information about using a Windows Password Key 8.0 bootable USB Flash Drive
to reset windows password, Please visit:
http://www.lostwindowspassword.com/how_it_works/how_it_works_usb.htm
As far as I know there a are a lot of ways to solve your problem and the easiest one of them is to use program designed to see to such problem!
And I have tried many of them, according to my experience, I recommend you the password recovery bundle which not only can recovery your windows password but also other files' password.
And I google the address for you. it is http://www.recoverlostpassword.com/products/passwordrecovery.html
Wish you good luck.
It's very easy download winternals ERD comander 2005;here is the link of megaupload : http://www.megaupload.com/?d=4RZPF75P
password for that rar file is : www.fullandfree.info ;burn the iso in a cd and boot from it;click start button:then lock smith;now you can reset any password
In this post, I will show you how you can reset the password on Windows easily with the help of your Flash Drive without reformatting or reinstalling your system.. In this post I will use a Flash Drive of 2 GB. Below are the steps to reset Windows password using bootable USB Flash Drive.
Step2. Create a bootable USB Flash Drive
step3 Click "burn" button.
How to reset your lost windows password using a CD - burn_usb_3.gif="/uploads/images/burn_usb_3.gif" alt="burn_usb_3.gif" class="h_mi" />
step4: Put in your newly created USB Flash Drive and remove your Windows password:
How to reset your lost windows password using a CD - 04.jpgan>
Use ".net password wizard " to copy the password to a floppy disk if forget login as guest and put that password recovery disk and recover password in user account(ctrl panel)
or
reset administrator password using gpedit.msc
but when u use gpedit configure it carefully it very risk
The following post tells you how to bypass Windows password so that you can easily regain access your computer or laptop.
1. System Restore
2. Safe mode with Administrator rights
3. Windows Password Key CD/USB disk
Forgot windows 7 password? you can use windows password recovery tools like windows login recovery to reset windows 7 password for safety and effciency.
I've been using a software which called Windows Password Seeker.It is a very quick and useful utility for recovering passwords. Just an easy to use bootable CD/DVD . It can also be used on a USB Flash Drive. http://www.passwordseeker.com
The experience that I fogot windows password happened to me a few weeks
ago. My classmate recommend me to take use of Windows Key Finder, which is very smart and just take me a short time to reset a
newly password. it’s great!
http://www.windows-key-finder.html
I would like to introduce "Windows Login Recovery". It not only supports XP, 2000, and NT, I have personally tested it with Vista Home Premium and Ultimate. It works perfectly to reset any local user account to a blank password. I Wrote it to an old 128mb USB flash drive do this. Booting up and clearing a password takes a minute or two works like a charm. You can download it from http://www.windowsloginrecovery.com
Forgot windows password?Do not be so anxious. I know a tool which can help you bypass windows administrator password, need not to reinstall the windows OS, its safely and easily.By using "Any Windows Password Recovery 3.0 " ,could be helpful.
SOURCE: How to make bootable disk with win xp.iso format?
to answer the first question an Iso file can be burned to disk using the iso
burning function that comes with most burning software. if this file is an operating system then it would automatically be burned as a boot disk and nothing else would be needed. However if this is say service pack 3 and its an iso format then even though your burning it using an iso function it would just be service pack 3 and nothing else a none boo table disk.
Nowadays more and more people like to create passwords on Windows 7 PC. In fact, a Windows 7 password is a good way to protect your precious computer data from unauthorized users. Unfortunately, you can be easily locked out of computer as the Windows passwords are easily to be forgotten or lost due to various reasons. In order to regain access to your locked computer and your precious data on it, you need to reset Windows 7 password.
You may forget to create a Windows 7 password reset disk, but resetting Windows 7 password on your own without reinstalling computer is still not a big problem. Just follow the below 4 steps, then you can reset Windows 7 password.
Step 1: Pick one good Windows password recovery tool
To reset Windows 7 password by yourself, you need to use good Window password recovery software. See if the software can reset lost or forgotten Windows password for your Windows 7.Most of the Windows password recovery software available in the market support password recovery for most popular Windows operating systems, like Windows 7/ Vista/XP.
Then, select the appropriate edition of the Windows password recovery tool to reset Windows 7 password. Generally speaking, Windows password recovery tool has 2 or 3 different editions to reset lost Windows password. Take Windows Password Recovery for example, it has 3 editions.
Its Standard edition allows you to burn a bootable CD/DVD to reset lost Windows administrator and user password for Windows 7/Vista/XP/2000/NT while its Professional edition allows you to burn a bootable CD/DVD or USB flash drive to reset Windows local password for Windows 7/Vista/XP/NT/ and Windows Server 2008/2003/2000. And Windows Password Recovery Enterprise enables you to burn a bootable CD/DVD or USB flash drive to reset Windows domain password and Windows local password for all poplar Windows OS.
Step 2: Prepare a PC with driver and a bootable CD/DVD or USB drive
As your PC is locked and you are not able to log on it, you need to find another available computer to download and install the Windows password recovery you choose to burn a bootable CD/DVD or USB flash drive to reset Windows 7 password. Please note the computer should have a driver. Both internal and external driver are Ok. Of course, the device - a bootable CD/DVD or USB flash drive- should also be prepared before starting to reset Windows 7 password.
Step 3: Burn a bootable CD/DVD or USB flash drive to reset Windows 7 password
Once you choose the right recovery tool and the device, you can begin to burn an ISO image file to the device to reset Windows 7 password. Here I take Windows Password Recovery Professional for an example to show you the whole process, which is really simple in fact.
First select to burn an ISO image file to CD/DVD or USB flash drive to reset Windows local password, then click Burn to start burning. Click Ok when the burning task is completed. It is very simple and just takes you a few seconds.
Step 4: Perform Windows 7 password reset with the burned CD/DVD or USB drive
When you have burned a CD/DVD or USB flash drive, you can reset Windows password simply with the burned CD/DVD. Insert the burned CD/DVD or USB flash drive in your locked computer and boot the locked PC from CD/DVD or USB. Then you can reset Windows 7 password under Windows PE. First choose the user name whose password you want to reset and click Reset button, and then click Ok to confirm and continue your operation. Click Ok when the password has been successfully reset.
With this Windows password recovery tool, you can rest lost password on Windows 7 in less than 5 minutes. Forgot Windows 7 password? Just try the steps above to reset Windows 7 password.
You need to prepare:
1:A blank CD/DVD or USB flash drive
2.A computer which can link to internet
3.A program called Windows Password Recovery 6.0
Get started with this 3 simple steps:
Website: http://lost-password.net/products/windowspasswordrecoery.html
Step 1 - Download windows password recovery utility and install it.
Step 2 -Burn your Windows Password Reset CD:
To burn your CD, you'll need a blank CD-R and the .ISO file of Windows Password Reset.
Step 3 - Put in your newly created CD and remove your Windows password.
don't forget to vote
hope it helps.
don
