Texas Instruments TI-89 Calculator Logo
Posted on Nov 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Urgenttttt --- when i used notefolio on my computer to transfer notes to my calculator TI-89... i could not find transferred notes on my calculator!! where can find it?? or do i have to download notefolio on my ti-89 calucaltor?? i tried, but it did not work out?
Anonymous
Level 2:
Sniper:
  • Expert 60 Answers
  • Posted on Nov 25, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
60
Questions
Helped
46390
Points
205
You need to install notefolio to your TI-89.
You can download the program from:
http://education.ti.com/educationportal/sites/US/productDetail/us_notefolio_89.html
After you download the program file, you can use TI-Connect to transfer the program file to your calculator (after you connect the calculator to the computer with the USB cable). To transfer the files, simply drag and drop the program file onto the TI-Connect icon on your computer.
To learn more about the Notefolio app, here is the guidebook:
http://education.ti.com/educationportal/downloadcenter/SoftwareDetail.do?website=US&appId=6204&tabId=2
Notefolio app not showing in my TI89
Transfer it to the calculator, if you have not done so already. If it has been installed, it should show on the AppsDesktop. To explore the desktop, use the arrow keys. You can also deactivate the AppsDesktop ON on the last page of the MODE, to have a list displayed when you press the Apps key. Once you find the NoteFolio app, select it and press ENTER. Here is how you proceed afterwards.
408bfaec-f5c9-4089-a6b4-c7517055caee.jpg 783a1491-192e-4456-bff2-413dd673ed51.jpg
9788439a-9d78-49af-a872-fb15d9f964ef.jpg bde1a278-c998-42ac-be27-f852b8ceeff9.jpg
Every time i connect my TI-89 to my computer it shuts off my calculator. I am trying to download notefolio because i cleared my memory and it deleted some of my apps. I have already downloaded ti connect....
Hi
its an hardware failure,
it could be that some liquid inside and it short the circuit
if you can open the back cover and look if there is some liquid or a battery leak inside
1helpful
I want to download apps to calculator... for example... i want to download notefolio on my calculator ti-89 but when i used ti-connect to trasnfer notes to my calculator i couldnt find notes on my...
if you downloaded with a browser like mozila or so ..it will be in a folder named Downloads..on my documents ..if you downloaded it with another one ...you have to check the download director for that program ...for example some makes the download director into my computer ..C drive ..downloads..
but if you are looking and can not find it ..just go to the start ...pres search ..and choose files and folders..and add the name of the file you search it ...if it is on computer it will find it for you ..than on the address bar you will see its location ..( or click right properties and go to file ..)
TI-89 i am very frustrated... i used graph link to transfer notes to my calcaultor but it said send failed. why? its really urgent i need notes to be transferred to my calculator. thanks!
My first answer is obvious: you can type them in the Editor.
Why did the transfer fail?
  1. File type incompatible with the OS.
  2. Not enough memory left to hold the file.
  3. Transmission error due weak batteries.
  4. Transmission error because the graph link end of the cable that goes into the IO port of the calculator is not fully inserted.
  5. Baud rate of your computer Serial port may be too high. Set it at 9600 bauds or less.
These are all the reasons I can think of. You may try to upadte the TI Connectivity software to the latest 1.6 version, if is not already 1.6
Hope it helps.
Thank you for using FixYa.
1helpful
Whenever i try to link my calculator with other ones it always says error in xmit. no matter what i do
Read the following answer from the TI Knowledge Base.
Hope it helps.
How can I troubleshoot an Error in Xmit error message when transferring data between two graphing calculators?
The Error in Xmit error message is returned when a connection cannot be established between two calculators when attempting to transfer data. There are several factors that can contribute to this error message.
• The calculators being connected are not compatible for data transfer.
• The data cable is not firmly connected to both units.
• The receiving calculator is not in receive mode.
• The I/O port on one of the graphing calculators is damaged.
The procedure for connecting two graphing calculators is as follows:
• Connect the data cable to the I/O port of each unit. The cable will fit tightly in the I/O port and snap into place. If silver from the cable is visible, the cable is not properly connected.
• Access the Link menu on each unit
• Place the receiving graphing calculator on "Receive"
• Place the sending unit on "Transmit" or "Send" from the Link menu.
Once the data has been selected, the transfer will commence accordingly.
The data transfer protocols for graphing calculator is as follows:
• TI-73 - Link allows data sharing with another TI-73, TI-82, TI-83, and TI-83 Plus.
• TI-82 - Link allows data sharing with another TI-82.
• TI-83 - Link allows data sharing with the TI-82, TI-83 family calculator, and TI-84 Plus family calculator.
• TI-83 Plus/TI-84 Plus family- Link allows data sharing with another TI-82, TI-83 family calculator, and TI-84 Plus family calculator.
• TI-85 - Link allows data sharing with another TI-85(To a TI-86. Not From a TI-86).
• TI-86 - Link allows data sharing with another TI-86 and from a TI-85 to a TI-86.
• TI-89 family- Link allows data sharing with another TI-89 family calculator and from a TI-92 family calculator.
• TI-92 family- Link allows data sharing with another TI-92 family calculator and from a TI-89 family calculator.
• Voyage™ 200 - Link allows data sharing with another Voyage 200 and TI-92 family calculator.
If the cable does not fit properly into the I/O port, or if the I/O port appears to be damaged (broken or separated plastic, obstruction inside the port), call 1-800-TI-CARES (1-800-842-2737) M-TH 8:00 AM - 7:00 PM FRI 10:00 AM - 7:00 PM Central Standard Time to speak to a representative or sending an email to [email protected].
How to transfer document from computer to ti83plus
Use ti notefolio creator software. It works w/ word and will tranfer to the calculator
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
