Question about Konica Minolta bizhub C351 All-In-One Laser Printer
I have a konica bizhub c351, I have changed my network here at the office. This IP address is 192.168.15.50 and now I need to change it to 192.168.0.50. Can you help me?
  • Konica Minolta Expert
  • 158 Answers
1.press the utility/counter button
2.select the administrator setting button
3.enter the password 12345678
4.select network setting
5.select tcpip setting
press forward button until you reach the tcpip addres section then you can change the address
Posted on Nov 25, 2009
    New Friend:
  • 44 Answers
Press Utility-administration-put in password 1,2,3,4,5,6,7,8 - press network then press IP.
Posted on Dec 06, 2009
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 8 Answers
SOURCE: Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Posted on Feb 02, 2008
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: Desktop faxing from Konica c351
Go to this link to get the fax drivers you need.
http://onyxftp.mykonicaminolta.com/download/SearchResults.aspx?productid=827&filetypeid=0&osid=3
You should have had a cd that came with the machine that has them as well. Once they are installed, go into Microsoft Word and select the fax to print from. A screen should appear asking you for the phone number of the name out of the address book.
Posted on Sep 26, 2008
herminio_hal
Herminio Halili, Jr.
  • 210 Answers
SOURCE: how to set scan for a new person on bizhub c351
If you know the ip address of the copier printer, it will be easier for you to add e-mail address. open the internet browser and type in the ip address. admin password 12345678. or use public. Click the scan tab.
Posted on Jul 09, 2009
Anonymous
  • 167 Answers
SOURCE: adding a new computer to scanning network of konica bizhub c351
Manuals:
http://help.bt.konicaminolta.ca
Utility/Counter button
#1 Create one-touch.
From here make selections until you find the one you want.
or....
Use your Web Browser to log into the device by entering the copier IP Address. From here you can create one-touches as well, and is easier.
Posted on Feb 09, 2010
I have a Konica Minolta BizHub C351 need to know how I can set up the ip address in order to be able to print to it. And any advice you can give me on the drivers using Microsoft Windows 7
Go to Konica Minolta web site US I assume down load driver for your machine. GO to Admin Settings PW 00000000 or 12345678 default. Network settings common setting to get IP address info
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 19, 2014 | Konica Minolta bizhub Office Equipment &...
Our Server was just changed; I cannot scan and retrieve that scan on my computer. How can I change the path on the Bizhub?
go to pagescope (web interface) by typing the IP address of the copier into any webbrouser address line. then go to scan and wallllah?? you got the settings
Jul 04, 2011 | Konica Minolta bizhub C351 All-In-One...
Describe your Konica Minolta bizhub C351 All-In-One Laser Printer Problem how to Assign an IP address to the machine
go to utility/counter button
go to admin
type in password
go to tcp/ip
go to second page
type ip address in
done
Feb 22, 2011 | Konica Minolta bizhub C351 All-In-One...
How do I find and reset the IP address on a Konica C351
Utility/Counter button, Administrator, 12345678 or 00000000 is password
select network setting. You can make changes to IP, DNS, Gateway, Subnet, SMTP , ect.
Apr 16, 2010 | Konica Minolta bizhub C351 All-In-One...
I HAVE A KONICA MINOLTA BIZHUB C351, I WAS MESSING WITH THE NETWORK CONFIGURATION AND NOW I CAN'T PRINT, IS THERE ANY WAY TO RESET IT TO FACTORY CONFIGURATION??? ANY HELP PLEASE...
First of All, Assign an IP address to the machine, if you already assigned the IP address, then Ping it from one computer to check its connectivity, now remove all the printers and printer drivers from your computer, and re-install the printer. if you want to reset the machine, then press the "utility/counter" button and turn the machine ON,(keep the button pressed) now from that machine reset the machine.
Feb 27, 2010 | Konica Minolta bizhub C351 All-In-One...
Adding a new computer to scanning network of konica bizhub c351
Manuals:
or....
May 01, 2009 | Konica Minolta bizhub C351 All-In-One...
Bizhub c350 will not scan to hdd
Easiest way is to change to SMB scanning which will give you direct scanning to PC or server. Create a new address in the machines address tab in the browser add the (must be a fixed) ip address of the machine it is going to with the folder name, user name and password and it will work a treat.
Mar 30, 2009 | Konica Minolta bizhub C351 All-In-One...
Weird scan problem with Konica Minolta Bizhub C351
It sounds like you have setup a fax forward box.
You need to set up a one touch, scan to SMB.
this can be easily done via your web browser by typing in the IP address of the MFP and set it from there.
You need the IP address of the laptop and is best to put the shared folder in the main drive (C).
Then for the file path you just need to enter the name of the shared folder EXACTLY as it is on the lap top.
You also MUST enter the ID a password to give it access.
Oct 14, 2008 | Konica Minolta bizhub C351 All-In-One...
Feb 01, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta bizhub C351 All-In-One Laser Printer Logo
565 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Clive
Clive
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
