Hoover U6434-900 Bagged Upright Vacuum Logo
Posted on Nov 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Belt replacement - Hoover U6434-900 Bagged Upright Vacuum
Anonymous
Level 3:
  • Master 701 Answers
  • Posted on Nov 25, 2009
Anonymous
Master
Level 3:
Answers
701
Questions
0
Helped
298520
Points
1875
Your model requires (2) different belts. Here is a link to the belts you need and to the manual:
U6434-900 Brush Roll Belt
U6434-900 Self-Propel Belt
U6434-900 Manual
How do I replace small belt on Panasonic MC-UG304?
Do you mean the beater bar belt or the motor shaft belt? If so, you need to set the vacuum in a horizontal configuration and turn the vacuum upside down. Next remove the five screws from the base plate and lift the base plate off.
To replace the motor shaft belt, remove it from the outer pulley and the motor shaft. Put the new belt on the motor shaft and the outer pulley. To replace the beater bar belt, release the motor shaft belt to allow access the beater bar. Lift up the beater bar assembly to remove the beater bar belt. Replace the beater bar belt. Replace the beater bar assembly. Replace the motor shaft belt. Turn the beater bar assembly by hand to check that the unit is seated correctly. Put the base plate back on the vacuum. Align the tabs on the base plate with the slots on the vacuum and replace the five screws.
The manual for the Panasonic MC-UG304 is available here: https://www.manualslib.com/manual/940210/Panasonic-Mc-Ug302.html . See page 5 for images of the steps.
I hope this helps.
2answers
What is the replacement belt number?
Shop for Eureka Vacuums What is... on Google
Eureka® Replacement...
$2.89
Staples Eureka Upright Vacuum Clea...
$5.99
Eureka Eureka Hand Vac Belt
$2.49
Eureka Eureka R Type Replacement...
$5.99
Bed Bath & B...
(4) Eureka AS1104 Drive Belt
$3.49
Google Trusted StoreeVacuum... Search Results
    Belts - Eureka
    www.eureka.com/en-US/Vacuums/Accessories/Belts/
    EurekaWith high-quality vacuum cleaner belts from Eureka, you can get better performance from your ... For optimum performance replace belts every 12 months.
    Eureka Replacement Belt for Upright Vacuum ... - Walmar
How to stop the main belt from comming off the motor shaft on a hoover modle u6634-900/windtunnel
Hello there! If you have replaced the belt and it is still slipping off, you may be not have the right belt for your vacuum. This unit takes a flat belt and a v-belt. Make sure you are replacing the belts with Genuine Hoover Parts. I have included the links below where you may go to order the belts specific to your cleaner.
WindTunnel PowerDrive Belt 2 Pack
WindTunnel Self Propelled Belt
Hope this helps!
2answers
I need to replace the belt. Have the belt and the vacuum bottom off. What do I attach the belt too?
This unit has 2 belts. The V-belt on the brush usually doesn't cause problems. The larger flat belt requires regular replacement ( belt # 38528-035 ). The belt is first placed around the motor shaft toward the rear of the machine, and then around the large pulley. You must have strong fingers to stretch the belt over the drive pulley. Start the belt at the top of the pulley, and try to "roll " it around the pulley a little at a time, holding the belt firmly around the pulley as you go.
Seems like the belt may be getting old and not picking up as much as it used to.
Belts need to be replaced periodically. If the belt is worn it will not pick up the way it should. You can get DC07 replacement belts here:
Replacement belts for DC07 w/ clutch system
Replacement belts for DC07 w/out clutch system
3helpful
Installing belt
here are the step by step instructions from the owners manual for your machine.
Disconnect cleaner from electrical outlet. WARNING: Agitator brush roll can start suddenly. Unplug cleaner before turning it over. Replacing Flat Belt Place handle in low position and turn cleaner over so bottom side is facing up. Remove the 6 screws as shown with a Phillips screwdriver. Lift off bottom plate. Replace belt if it is stretched, cut or broken. To check the flat belt. Removing Bottom Plate Removing Belt Positioning Belt Remove used belt from large pulley and discard. Reposition bottom plate and 6 Phillips head screws. Tighten screws securely. Insert agitator brush roll through belt and position belt in groove (A) on agitator brush roll. Inspecting V-Belt The V-belt is designed to last for a long time and is not normally replaced. However, if the V-belt is cracked, gouged or broken, it should be replaced. Slide flat belt off large pulley. To remove V-belt, slide back of belt over pulley (A). Then firmly pull on belt and “snap” it out. Discard used belt. To install new belt (with lettering on outside of belt), slide back of belt over pulley and pull front of belt toward groove next to pulley. Belt will “pop” into place. Flat Belt: What to Buy Use only genuine HOOVER belts with your cleaner. When purchasing a new belt, ask for Flat belt - HOOVER part No. 40201-271. V-Belt: What to Buy Use only genuine HOOVER belts with your cleaner. When purchasing a new belt, ask for V belt - HOOVER part No. 40201-200.
If you can't get the answer from this post, send me a message and I will try to walk you through this. I hope it helps.
2answers
Need to replace vacuum belt
how do i change belt on morphy richards ultralight cyclone cleaner?
Jan 04, 2009 • Vacuums
2helpful
Kirby g4 belt replacement
Facing vacuum,turn belt lifter knob counterclockwise till it stops.Lift headlight hood,and unlatch brushead,and remove.Looking thru the hole in back,turn belt lifter knob clockwise to release belt.Remove bottom plate,and bend one end of bracket to remove end of brush roll.Slip new belt on and replace brushroll back into bracket,and replace bottom rug plate.Looking thru hole in back,turn belt lifter knob until the hook inside picks up belt.Replace brushead,and again,turn belt lifter knob clockwise to drop belt onto shaft.
Dec 18, 2008 • Vacuums
How to replace a belt successfully on a Bissel Powrforce 3522?
How do I replace the belt? I don't know how to get into that area.
1800 vacuum cleaner belt replacement
Generic problem for all Vacuums
How do you get into the belt to replace it?
Not knowing the brand name of the vacuum other than the 1800 vacuum cleaner belt replacement, normally the belt is located @ the bottom the vacuum attached to the brushroll and is held on by either screws, clips, or some even snap on – but mostly they use some type of screws to open the area to replace the belt, if needed contact the company website, include the brand name and the model number and request a schematic of the vacuum and that will give you an exploded view of how the vacuum assm goes together and also shows the belt replacement and how that is connected.
http://www.dooyoo.co.uk/vacuum-cleaner/typhoon-1800-upright-vacuum-cleaner/1021772/
Apr 07, 2008 • Vacuums
Top Hoover Vacuums Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
