There will need to be a recall, everyone is having the same problems across the country. Rheem is finally taking notice. Call your dealer and they may replace unit.
Remove power source from the unit. If remote control is installed; remove cover and lift the control wires on the terminal...can be accomplished from either end. See if the unit runs longer.
If you're receiving any error codes, especialy code 76; contact RHeem customer support at (800-432-8373) and notify them IF you are getting a code "76" error.
Good luck,
JZ...
Temporary solution:
Set your temperature to about 115, that way you use more water flow which should keep it from shutting off. OR to the temperature that you can handle W/O cold water added. But that will help you for a few weeks only. Also while you shower or use hot water you can open an extra faucet to keep high flow.
Temporary solution:
Are you getting any error codes?
Do lyou have a remote controller? Are you getting any error codes? Mike...
is there a water screen or filter...could be clogged...check manual to clean
