Fisher Paykel EcoSmart GWL15 Logo
Posted on Jan 13, 2008
Ecosmart loud during spin cycle
Our Ecosmart recently became very loud during the spin cycle -- almost sounds like a bad bearing? Still completes the cycle and clothes seems as dry as usual, just very loud during the high-speed spin.
  • Anonymous Jul 11, 2008
    Having exactly the same problem, I am going to change the bearing to see if that fixes it. I take it that you have fixed your problem by now so this is just for reference.
Anonymous
Level 1:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Jan 14, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
Helped
15065
Points
20
My majestic sounds exactly the same on the spin cycle and I wondered what the problem was. Is your unit still under warranty? If so, call the customer service line and get a repair started. I am a firm believer in warranty work on products I have purchased. WE pay hard earned cold cash on our consumer products and WE should be taken care of properly.
Good luck and please let us know what the solution was to your problem.
  • Anonymous Feb 27, 2008
    Update on our machine. We replaced the bearing and the screetch is completely gone. How has yours turned out??
    Coffeediva22
  • Jennifer Killian Aug 30, 2019
    what model is your washer? mine is a GWL15. if yours is the same do you remember what part # was for the bearing kit you ordered?
1helpful
2answers
Motor or bearing sounds bad, how do you replace it
You have to unscrew certain body areas to get into the motor area depending on the make and the first thing I would check is see if the belt is shot. A bad belt will make noises as well as cause slipping. If the belt is ok check the shafts and see if there is play like movement if you push up or down . If it's the motor you may have to replace or take it to a repair shop if you don't understand how to do it. It does take some work to change a bearing
Are there bearings for the drum for the LG1812? It became very loud during the high speed spin and there is play between the tub and the tub enclosure.
Loud rubbling during the spin cycle would definately indicate that the bearings have failed. Bearings can be replaced, and can be found online as repairclinic.com, but it is rather difficult job if you are not mechancally inclined.
3answers
Loud noise during washing/rinsing cycles
I just replaced the bearings on my Front loader Maytag MAH5500B, as it sounded like a freight train during the spin cycle. The bearing replacement fixed the train problem.
NEW PROBLEM NOW: It's been about a month now since the bearing job and now something is clicking/binding when you spin the back belt wheel. I have taken the belt off and carefully move the wheel and I still get this clicking noise. It sounds as if someone is hitting the plastic drum that the tub is surrounded by. I really doubt it's the bearings this soon, as the sound is not the same! No leaks or metal shavings to speak of or rubbing of the belt wheel.
Seems like it's more noticeable during the wash/rinse cycles then the spin.
Can anyone help.???
Loud noise during spin cycle
is it more like a roar or a train going by? if so your rear tub bearing is going out. very expensive have to replace the tub, basket, spinner ring and shaft and seals about 4 hrs for an exprienced tech to do took me 7 hrs to do for the first time. but it will be very close to $1000 to have done not much less to do it yourself.
Very loud during the spin cycle
the top bearing has gone bad you are looking at replacing the transmition and tub seal about 200 dollars in parts the labor is a little tough also you got to completly disasemble the machine to do this may be best to get a new machine
Very loud on spin cycle
yes ..bearing on upper side of gearcase has gone bad probably from a water leak from tub seal
4helpful
2answers
Frigidaire top-load washer Loud noise during spin
its either the upper spin bearing or lower spin bearing. the upper can be replaced by itself but the lower requires the transmission the be replaced
13helpful
2answers
this is my experience repairing the maytag washer Atlantis mav series 9750 aww, I had to replace the spin bearing since it was making a jet engine noise when it was spinning out the water. its not an easy job for my 1st time taking this machine apart, you literally take it all apart to get to this bearing, but now I can show how to do it with pictures making it easier for you to do it. even if you have to replace something other than the spin bearing, this how to tutorial will show you how to get to most of the parts in this machine
tutorial located here tutorial located here https://sites.google.com/site/maytagwasherrepair/maytag-washer-repair
Top Fisher Washing Machines Experts
Paul Bade
NOEL
NOEL
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
