Try this
Here is the link to get the manual. http://www.caralarm.com/manuals/MARS/MARS-22.pdf
See pages 20 & 21 ( see picture) With the engine running you will turn either the Smart Start or Tach Wire adjust screw, depending on which setting your box is set on. You will turn one or the other until the LED LIGHT blinks consistently.
SOURCE: remote programming
The above web address will give you the information you are looking for.
SOURCE: My 2007 Ford Edge W/ Mars 22 remote start will
put your key in the ignition leave it in the off position, push your remote start button, if it starts then it has something to do with the transponder bypass "key in the box" or the loop around the ignition switch under the plastic cover
