I can't find how to reset my Lumix DMC_TZ1 to factory specs.
SOURCE: Lumix DMC-TZ1 says Please turn
I had the same problem. I turned on and off several times with the same message and issue. It appears to be a lens issue. I hit it several times firmly on the bottom with my hand while on and must have jarred something loose because it started to function again. Whew!!!!!!!
SOURCE: Lumix DMC-FX01 Buttons not working
Remove the card and battery. Clean the battery contacts inside camera with a cotton swab lightly dampened with rubbing alcohol. Be sure battery is charged. Press all buttons on camera. Insert card and then the battery. See if it works. If you can now get into the setup menu, you can do a reset from the menu.
SOURCE: Lumix DMC-TZ1 Memory Card Error
Try formatting the new card in the camera. Also, download any pics from the old card using a card reader and then, format it in the camera.
My camera has been connected to a computer with virus "bittorent", and that has probably messed up the internal programming. It does not want to connect to a computer, even not when the setting for USB are set to PC.
I have tried to reset as explained at the troubleshooting (go to reset and on both options pess 'yes', but no change; there is no connection to PC.
