Question about Mitsubishi VS-50111 50" Rear Projection Television
Tv comes on and has no picture. menu there, video on monitor jack
Tv comes on and has no picture. Has sound and menu's video comes
out monitor out jack. no video
going to the CRT's
    Genius:
  • Mitsubishi Master
  • 1,039 Answers
This an old tv. From my experience i would replace it. It will be a money pit.Crts are beyond there life expectancey.
Posted on Nov 25, 2009
6ya staff
SOURCE:
Replace tv video card
FOLLOW this steps and fix it. God bless you
Perform some basic troubleshooting steps that apply to all TVs. These include checking the "Mute" button to see if it has been pressed, examining the L/R balance to ensure sound is coming from both speakers and checking the cable connections to auxiliary components such as the stereo system (which controls external speakers).
    • 2
Double-check the audio output jacks if you are using an S-video connection (a single round perforated jack) or component video connection (a trio of green, blue and red jacks). Those jacks only run the video signal to the RCA TV. In order to get an audio signal, you'll need to connect red and white RCA cables to their respective jacks on the TV.
    3 Check the back of the TV for a switch labeled "Int/Ext." It controls the sound input on some RCA TVs. If you don't have any separate speakers, the switch should be set to "Int."
      • 4
    Activate the sound set-up feature by pushing the "Menu" button and scrolling to the sound bar. (This option can usually be found only on RCA flat-screen and projection screen TVs.) The sound bar allows you to set the sound from mono to stereo, activate the surround sound features, adjust the sound for headphone use, set volume levels and activate preset sound levels for movies, sports, concerts, video games and other specific sorts of programming. If any of these settings don't match the configuration of your home theater system, it may cause problems with the sound. If you're confused about the options, select any settings that read "Normal" or "Automatic." That should set the RCA TV to factory standard audio settings.
      • 5
    Press the "Menu" button and scroll to the "Set-Up" option, then go to "Preferences." You'll see a bar on the menu marked "Maximum Volume." You can use that to limit how loud the TV can get, which can cause problems if you don't know it's been set. Move the arrow on the bar to reset the maximum volume, then hold down the "OK" button on the remote to hear what that volume sounds like. You can then listen to the TV as normal.
    Jul 20, 2013 | Sylvania Televison & Video
    Hmm.. I doubt you will be able to help me, and if you can, it won't be free, but here's my question anyway: any idea why when I try to connect an s-video cable from my harman kardon avr 130's Video 1...
    Well, use the "Monitor Out" jack on the receiver, as that is what it's designed for.
    Is there a jack labeled "Video 1 Input" or only "Video 1 Output"? It could be that the Harmon Kardon folks have a weird way of labelling so that "Video 1 Output" is actually an "input" to the amp that is then fed thru the "Monitor Out" jack. It will take some experimenting on your behalf. Some units will also NOT take an input or output thru the S-Video IF you have a composite cable connected to the (yellow) composite video jack for that same point, so make sure that is disconnected if you want to use the SVideo. Also, sometimes there is a menu setup in your monitor where you have to decide between Composite video or SVideo or Component Video, so check that in some cases as well.
    Let me know what you find out.
    Mar 12, 2011 | Audio Players & Recorders
    I cannot get any sound through my tv from my acer ao531 notebook i have a picture but no sound
    Try these options
    1. Click on sound icon in Taskbar and make sure sound is up on HDMI volume. If this doesn't exist-
    2. Start => Control Panel => Hardware and Sound. Under Sound tab click on Manage Audio Devices, right click on HDMI tab and enable. Or this: Computers have two seperate systems - one for video and one for sound.
    The only computer (or laptop) connection that carries both video and sound is HDMI. If you do not have a HDMI/DVI connector on the back of your computer, then you will have to use the VGA-composite or s-video connectors to display your PC's output on an external monitor like an LCD TV.
    On both my HP and Dell laptops the display settings (Start/Control Panel/Personalize/Display Settings) allow two modes - single or dual monitor mode. Single monitor mode allows me to switch between any one of three possible video outputs - VGA-composite, S-Video or laptop screen, or a split-desktop (display spread over two seperate monitors). Dual monitor mode allows the same display on any two of three possible video outputs.
    Switching is performed using the fn keys on the keyboard (fn key plus the F2, F8, etc. function key with the display marking). You guys use single monitor mode until you figure out what your are doing. Select VGA-composite or S-Video.
    Non-HDMI sound to your TV monitor or sound system must be obtained from your laptop's Headphone or S/PDIF jacks. Headphone is stereo and S/PDIF is 5.1 surround sound. Headphone is electrical, but S/PDIF may be electrical or optical (laser light). You must set the sound jack that you intend to use as the default on the PC control panel (Start/Control Panel/Sound).
    None of these connectors is two-way in the context of an LCD monitor - your PC cannot record a TV picture or sound from the external monitor. To accomplish this you must purchase a video converter box that converts cable TV or video+sound inputs to USB format usable by your laptop. Do this and you can turn your laptop into a Tivo recorder/DVD burner using Beyond TV, Sage TV or a variety of other software packages.
    Mar 10, 2011 | Computers & Internet
    We have our cable box hooked up to the tv and get a great picture but no sound. The previous owners had a stereo system hooked up to the tv and we are simply trying to get any sound at all. We went into...
    Ok, I need more verifications:
    1) Your TV is Fujitsu Siemens PlasmaVision P42VHA40 Monitor which does not have tuner? If not, please provide the make and model of the TV.
    2) What kind of cables you are using to hook between the cable box and the TV? HDMI? Component video (Red, Blue, and Green cables withe RCA plugs)? Composite video cable with Yellow RCA plugs?
    3) Are you trying to get the sound to come out off the TV speakers or through the stereo system?
    Feb 03, 2011 | Fujitsu Siemens PlasmaVision P42VHA40...
    Cant get any sound on tv
    On both my HP and Dell laptops the display settings (Start/Control Panel/Personalize/Display Settings) allow two modes - single or dual monitor mode. Single monitor mode allows me to switch between any one of three possible video outputs - VGA-composite, S-Video or laptop screen, or a split-desktop (display spread over two separate monitors). Dual monitor mode allows the same display on any two of three possible video outputs.
    None of these connectors is two-way in the context of an LCD monitor - your PC cannot record a TV picture or sound from the external monitor. To accomplish this you must purchase a video converter box that converts cable TV or video + sound inputs to USB format usable by your laptop. Do this and you can turn your laptop into a Tivo recorder/DVD burner using Beyond TV, Sage TV or a variety of other software packages.
    Please let me know if you have any further questions or concerns.
    Thanks.
    May 07, 2010 | HP Compaq Presario C700T
    I have picture but no sound LG flatron TV and Pioneer DVD player.
    connect audio output (RCA Jack white n red color) from the video, to the audio input of your TV. Make sure you use same AV channel for the video and audio.
    i.e AV1 or AV2 or AV3
    Apr 10, 2010 | LG Flatron MW-30LZ10 30" LCD Monitor
    When i connect my laptop to the tv i get sound but no pic.
    Feb 11, 2010 | Dell Studio 1537 Laptop
    Hi there i am trying to connect a samsung lcd monitor to my pc via HDMI. i have the connection showing picture on my tv, however where i connect a 3.5mm jack from pc to tv no sound comes out. i have...
    The connection to your tv is video only. You should hear sound coming from computer speakers. Unplug them and hook your stereo to that plug in.
    Oct 04, 2009 | Computers & Internet
    No sound_RCA_model L23W10_Only Ear Phone Jack Provides Sound
    Hello... I found the following in the user manual for this TV. Also, some RCA models have a speaker switch on the back of the TV. If none of this solves the problem, your TV may need service. I hope this helps...
    Sound problems, picture okay
    • Maybe the sound is muted. Try pressing the volume up button to restore sound.
    • If using S-Video or Y Pb Pr, remember to also connect the component's left and right audio output jacks to the TV's AUDIO jacks.
    • Make sure the Volume option in the Sound menu is turned up.
    • Make sure headphones aren't connected to the headphones jack.
    Nov 17, 2017 | RCA L23W10 23 in. LCD Television
    Picture but no sound on Hyvision LCD monitor MV190
    I had the same problem. The speakers are mounted below the the LCD Monitor. There is no internal connection between the speakers and the TV Audio. There should have been a short patch cord in your box having one jack on one end and two wires with mono jacks on the other. Plug the stereo jack into the audio out on the monitor and then plug the other jacks into the left and right side of the speakers (the wires should be marked L and R). If you cannot find the jack, I'm sure that you can find one on line or get one from Radio Shack.
    Nov 07, 2007 | Gateway FPD2275W LCD Monitor
    Mitsubishi VS-50111 50" Rear Projection Television Logo
    Top Mitsubishi Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
