Question about Technics SL-1210 Turntable
1210 mk2 only playing through left speaker checked everything and needs new rca phono lead how easy is it to change thanks
    Novelist:
    Champion:
  • 382 Answers
If you have done some soldiering and have a steady hand, it's not difficult. If you are not sure, you could destroy that little circuit board that the lead runs to, and technics had discontinued production of that part. I'd say get it done by a pro with experience.
These guys are top notch:
http://www.repairnyc.com/
Hope this helps.
Posted on Jan 14, 2008
SOURCE:
Turntable only playing in one speaker
In my business I work on a lot of turntables. Specifically, Memorex, Anders Nicholson, Innovative Technology and Emerson. 99% of the time when I only have sound coming out of one channel it is due to a broken cartridge. If you look at the tone arm head from underneath you will see a rubber fork that the needle arm sits in. There are usually 2 ceramic cartridges attached to the rubber fork. Those transmit the sounds from the needle. If one of those brakes then that channel will not transmit any sound.
Dec 07, 2011 | Technics SL-1210 Turntable
Very low volume from my technics sl6 even when tuner is turn up to max. volume.
Hiya, first and foremost, is it plugged into the amps correct sockets? Turnatables have to in the PHONO (turntable) Any others , CD, AUX, MIC etc will not work. (sorry if that seems obvious, wasnt sure on the info provided)
If that is OK then check the stylus, probably requires a new stylus or/and cartridge.
Best of luck
Jul 16, 2009 | Technics SL-1210M3D Turntable
One of my turntables only has sound coming out of left speaker..
one of your phono leads ether red or white is nakered.plug them in one at a time and see witch ones workin,then youll no the dodgy one.when you pull out leads from your mixer you can sometimes break cables free from the fittings if pulled by the wire.you wanna re soilder a new lead on to deck or pull back the sheath plastic covering the fitting and reconnect the cables(the insulated wire goes to the pin an the uninsulated goes to outside ring)gd luck
Jun 13, 2009 | Technics SL-1210 Turntable
Broken lead needs to be replaced
I have been hiring technics for years and this is a recurring problem, you have to replace the phono connection or worse the whole lead, sorry
May 06, 2009 | Technics SL-1210 Turntable
Dj decks-no sound
You didn't state if you purchased this used or new. If used, maybe the tonearm or the rca cables are bad. Or, if you set it up inccorectly.
Just to be sure...
TURNTABLE -> MIXER PHONO INPUT (CH1 or CH2) -> OUTPUT MIXER (MAIN OUT) -> STEREO INPUT (AUX IN or LINE IN).
Make sure you have the line selected properly on your receiver, and if you have a tape function, press the button in and out. Sometimes this will affect the sound. Now, check to see if your getting any signal to your mixer. Make sure the toggle switch on your mixer is set for PHONO and not LINE. Raise all volumes, including heapdhone, and see if you hear or see anything on the levels.
If all is good, but no signal going to mixer, then you might have a bad tonearm or RCA cables....
To check, disconnect the cartridge/headshell from your tonearm. Look inside the tonearm, and you'll see 4 gold plated prongs. Make sure they are all evenly protruding. Also make sure they are all a shiny. If you see any black substance on any of the prongs, they need to be cleaned. If any look like they are stuck, and not sticking out like the other ones, this would also cause an issue. This cannot be repaired. You can try to get the prong to come out, but if it does not work, you will have to replace the tonearm.
If everything with the tonearm looks good, then the issue might be the RCA cables. There is no easy way to check this, other than opening up the turntable. This is not easy, and I do not recommend.
Let me know how it turns out.
- OPTiC
DIY Yourself DJ Repair Videos
DJ Equipment Sales
Jan 07, 2009 | Technics SL-1210 Turntable
Sl 1200 mk2 no sound comming out new needle
It sounds like the rca (phono) leads also check your cartridge.
Regards.
http://www.audiovisualservices.info/
Dec 16, 2008 | Technics SL-1200MK2 Turntable
No sound out of deck
If you've already replaced the RCA /Phono cables, then the only other item that would cause this kind of problem is your tonearm, and it will need to be replaced.
- OPTiC
DJ Turntable Repair Expert
A DJ Pro Audio Co.
Dec 05, 2008 | Technics SL-1200 Turntable
Ok this problem is killing me...
maybe the speaker is bad
First try one thing, switch the rca jacks around and see if the other speaker stops working this time.
If so the problem is in the rca jack or head unit.
If the same speaker is still not working, the problem will be the speaker, you will have no other options left since you changed amplifiers and checked all wiring.
Let me know if this helps you
Jun 18, 2008 | Visonik Dual Bass Box with Amplifier Car...
No sound from CDJ-800 MK2
Are you getting error messages? Running in thru LINE? Is not on mute? The possiblity of both not playing would lead to process of elimination.
Keep me posted.
Oct 19, 2007 | Pioneer CDJ-800 Turntable
RCA Phono plugs
replace the rca leads, make sure the ground lead is tethered, make sure the lines arent crossed under the headshell....but soldering a fresh pair of rca, usually fixes that....Also remove the headshell/cartridge, and see if there is any residue in the 4 contacts in the tonearm....
Sep 25, 2007 | Technics SL-1210 Turntable
Technics SL-1210 Turntable Logo
174 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
