First check the surface between the rotor and the coil and make sure there is no rust. If there is take some fine emery cloth remove the rust from both the rotor and coil. Use a noncondutive cleaner to remove any metal particals. If you remove the coil you can use a standard business card to reset the gap.
After completing this process if it still does not start check the plug and make sure you have a spark in the plug gap. You can test it by removing the plug and reattach the plug wire then lay the plug on the head and try starting the engine. The spark should be a bright blue. If you do not have any spark recheck the plug gap. If the spark is a red color your coil is weak and needs to be replaced.
