Posted on Nov 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Acu-Rite indoor outdoor thermometer (model 00754) with wireless sensor beeps every couple of hours. Batteries are all new, reset repeatedly, alarm is off.
Sys Admin
Level 2:
  • Expert 73 Answers
  • Posted on Mar 02, 2011
Sys Admin
Expert
Level 2:
Answers
73
Questions
0
Helped
46848
Points
472
There is no way to turn off beeping. From this site: http://www.chaneyinstruments.com/FAQ.aspx
found solution - Q: My wireless weather station periodically beeps, why?
A: Make sure that any alert and/or alarm features are deactivated first. Constant, sporadic beeping is generally due to the unit's ability to detect a foreign radio frequency of another wireless unit when that unit transmits a signal. Wireless devices that may cause beeping but are not limited to these devices are; scanners; computers w/wireless keyboard/mouse; or other wireless weather instruments. Essentially, any wireless devices transmitting on a radio frequency have the potential to interfere with each other. Limit the amount of wireless devices to lesson the chance of interference. When beeping occurs, one device will need to be deactivated.
Another external temp gauge showed up on the other channel, so my neighbor or someone is using the similar unit. MY SOLUTION: opened back of case and cut black wire to piezo speaker (at base if rear cover opposite side of stand-up prop) that creates beep. ALL good now.
  • Anonymous Jun 30, 2012
    I replaced my batteries in my main unit, then put my main unit and the remote sensor side by side. I removed the batteries from the remote, waited a minute, then re-installed the batteries. I set the C/F, then pushed "Transmit." For me, this worked and the beeping stopped.
    More here:http://www.acurite.com/manuals/00754.pdf
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 30, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3725
Points
1 Related Answer
fixya-surfer
Sys Admin
  • 73 Answers
SOURCE: Acu-Rite indoor outdoor thermometer won't stop periodic beeping
found solution - search for - Q: My wireless weather station periodically beeps, why?
A: .. unit's ability to detect a foreign radio frequency of another wireless unit when that unit transmits a signal. .. any wireless devices transmitting on a radio frequency have the potential to interfere with each other. Limit the amount of wireless devices to lesson the chance of interference. When beeping occurs, one device will need to be deactivated.
There is no way to turn off beeping, d/s designers forgot. I had the same problem, another external temp gauge showed up on the other channel, so my neighbor or someone is using the similar unit. MY SOLUTION: opened back of case and cut black wire to piezo speaker (at base if rear cover opposite side of stand-up prop) that creates beep. Don't use any sound features, ALL good now.
AcuRite Remote Sensor 00605TX for Acu-Rite 75321A1 Weather Station. I can't get my 00605TX to reset.
Question edited for a LOT more clarity. full 'make model (what it is)'.
Question moved from Computers to Model category.
Remove the batteries from both indoor and outdoor unit. Leave them out for 10 minutes. Replace the outdoor sensor with a new battery (2xAA), and then new batteries in the main unit (3xAA).
00605 Wireless Weather Station + Companion Instructions
AcuRite https://www.acurite.com > media > manuals > 0... PDF NOTE: When replacing the batteries for the wireless sensor, remove the batteries from the sensor and clear that sensor's channel on the main unit by pressing ...
6 pages
Hard Reset for Sensor Models 00606TX/06009RMA1 & ...
AcuRite https://support.acurite.com > en-us > articles > 360007...
The following reset steps can be performed to correct issues of the sensor not connecting to the display. Symptoms of the sensor not...
https://fccid.io/RNE00605TX/User-Manual/User-Manual-707183
1helpful
How do I reset the remote after changing the battery life.
To reset your unit, please verify that you are using a good-quality, standard alkaline battery such as Energizer or Rayovac. Then, follow the steps below.
1. Bring both the sensor and display unit indoors and remove at least one battery from each.
2. Make sure the A-B-C switch on both units match. Sometimes changing to a different channel can help.
3. Reinstall the battery in the outdoor sensor.
4. Reinstall the battery in the display unit.
5. Let the units sit within a couple feet of each other for about 20 minutes to gain a strong connection.
If you need any further assistance, please contact AcuRite Customer Support at 1-877-221-1252 or [email protected].
1helpful
Acurite wireless weather will not work new last season all new lithium batteries in right and were checked no picture #'s on screen
Hi Jerry,
While lithium batteries are recommended for the outdoor sensor it is not recommended they be used in the indoor display unit. Try using a good quality, fresh alkaline batteries and you should find your display turns back on.
Acu-Rite Wireless Thermometer indoor/outdoor, the only identifying number I can find is inside where the batteries go, a sticker says: 0417. Question: 1) On the indoor piece, I can set the clock to the...
Before attempting to set the time, let the outdoor transmitter sync with the indoor receiver. Once that's done, you'll be able to successfully set and retain the date and time.
3helpful
My acu-rite wireless thermometer model #00604RX isn't capturing the wireless sensor signal..both have new batteries and worked before changing old battery..reset the buttons too...help
Double check the batteries and the direction in which they are installed. If there is one backwards in the sending unit that is outside, it will not send a signal. Also, there is typically one battery in the indoor unit that is responsible for receiving the signal from the outdoor unit. If all of the batteries are in correctly except that battery, you will see the display, but will not get the data transmitted from the outside sending unit.
2answers
18helpful
2answers
Top Acu-Rite Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you an Acu-Rite Audio Player and Recorder Expert? Answer questions, earn points and help others
