HP FAX 1250 Fax Machine (Black) Logo
Posted on Nov 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hp printer 6313 all in have problem for fax. error number 351
Anonymous
Level 2:
  • Expert 231 Answers
  • Posted on Dec 07, 2009
Anonymous
Expert
Level 2:
Answers
231
Questions
Helped
112839
Points
632
The machine has a ECM (Error Correction)error.
Could be:
  1. The remote machine has failed to respond.
  2. The remote user has oressed the Stop button.
  3. Incompatability between two machines may cause the remote machine to abandon the call.
Try turning off ECM in the Fax Settings Menu.
I can not receive fax but i can send fax the printer hp officejet5610 was at the client he receive the error that says fax fail brought the printer to my workshop the printer gives the same error please...
Hi, Make sure that the fax header contains the full 10-digit telephone number of your HP fax product, including the area code.
  1. To modify the fax header, use the following steps:
    1. Press Setup on the product control panel.
    2. Press Basic Fax Setup , and then press Fax Header .
    3. Type personal or company information using the keypad, and then press OK .
    4. Type the phone number, including area code, for your HP fax product, and then press OK .
Regards,
Riztech
1helpful
I am trying to send faxes and keep getting error 351* what is this?
How to easily fix (error 351)? There are two (2) ways to fix 351 Error:
Advanced Computer User Solution (manual restore):
1) Start your computer and log on as an administrator.
2) Click the Start button then select All Programs, Accessories, System Tools, and then click System Restore.
3) In the new window, select "Restore my computer to an earlier time" option and then click Next.
4) Select the most recent system restore point from the "On this list, click a restore point" list, and then click Next.
5) Click Next on the confirmation window.
6) Restarts the computer when the restoration is finished.
Novice Computer User Solution (completely automated):
1) Download (Error 351) repair utility.
2) Install program and click Scan button.
3) Click the Fix Errors button when scan is completed.
4) Restart your computer.
hope this helps..pls rate if this helps thanks
2helpful
2answers
Hi my HP printer fax was working fine but now I am getting a 351 error message I rang the fax print test and everything seemed fine there
    1. On the product control panel, press the setup button (c01661990.gif ).
    2. Use the right arrow key (c01661991.jpg ) to select Advanced Fax Setup , and then press the OK button (c01335940.jpg ).
    3. Use the right arrow key (c01661991.jpg ) to select ECM , and then press the OKbutton (c01335940.jpg ).
    4. Use the right arrow key (c01661991.jpg ) to select Off , and then press the OK button (c01335940.jpg ).
    5. If the ECM is off try turning it back On
    6. Check All these other settings
    7. Press the Setup button c01661990.gif Go to Advanced fax settings and check if the Fax speed is set to medium
          1helpful
          2answers
          Error Codes
          Hi Sir
          this is very common error that happens in fax
          i am sending a link which has all the things of hp
          please follow that arcticle it is going to resolve the issue for you
          http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&dlc=en&docname=bpu02549
          HP Officejet D Series Multifunction d135 Error Message Interpretation
          Hi Sproutman.
          Please click on the web link given below and perform the steps provided in the web page to get the issue fixed.
          http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02549&cc=us&lc=en&dlc=en&product=64986
          Click on the web link given above.
          Scroll down to the error code and read the error code.
          k24674
          Grand Canyon Tech
          Grand Canyon Tech
