The dryer of my washing machine is not rotating.?The dryer of my washing machine is not rotating. I opened the dryer cabinet and make the supply on, I heared the sound of motor that it try to rotate, but it was unable to rotate the dryer tyb. I disconnect the tub and checked the motor rotation, it was free and not jammed at all. I again connect the supply, again motor sounds, but it did not rotate. Please guide me what next I have to do?
Thanks
Asad,
The other comment may be correct but I am not sure that you do not have a broken belt. If the motor is running...not trying to start and clicking off...the problem is the belt. The old one may be jamming the drum up.
Asad, if you are hearing the motor trying to start I would start with the motor capacitor. Looks like this model has a wash and spin side. Each side has a capacitor for the motor. The manual is not too informative but it looks like there is a switch that has to be made too. But if you are hearing the motor humm, I would start with that motor capacitor
Loud noises coming from a Washing Machines are most often caused by loose objects inside the unit or by a broken dryer belt. The Washing Machines belt allows the dryer's motor to run smoothly. Continuous wear and dry conditions may cause the belt to dry out, eventually Washing Machines cracking and then snapping. This will cause a loud noise within the unit. Repair and fix the dryer belt of a Washing Machines to get rid of loud noises.
Instructions And Things You'll Needed to solve the problem.
Screwdriver ,Replacement Washing Machines belt
1 Stop the Washing Machines and look inside the dryer's drum for any loose objects such as coins, pens or anything else that may have been in a pocket of clothing. Remove the object and restart the dyer to determine if the noise has stopped.
2 Unplug the Washing Machines from the wall outlet to disconnect all power to the unit.
3 Remove the lint trap from the lint compartment on the top of the dryer.
4 Remove the screws that hold the top panel in place. Pull the panel off to access the
dryer belt.
5 Tilt the dryer forward and lift the dryer drum to remove the belt. Check the Washing Machines belt. A belt that is worn, cracked, split or broken will cause loud noises.
6 Slide the old belt off of the drum and pull it out to remove it. Take note on how it is positioned over the drum.
7 Install the new belt. Lean the front panel away from the Washing Machines and slip the new belt over the drum. Locate the position of the old belt and slip the new belt following the old belt's position ensuring the grooved side of the belt faces down. Push the idler pulley towards the motor to allow you to slip and loop the belt around the motor pulley.
8 Place the top panel on the Washing Machines and screw it in place.
9 Open the Washing Machines door and use your hand to rotate the drum counterclockwise a few turns to ensure the belt is secured.
10 Plug the Washing Machines into the wall unit and begin use .
