No sound, so far everything else seems to work. we have tested and checked all the wiring, other game consoles have sound but not our wii, so we believe everything is correctly connected.
same problem checked the leads all in the right place still no soundsame problem checked the leads all in the right place still no sound
AnonymousMay 26, 2008
I need to know if Wii comes with sound. Mine does not. I am plugged into the TV front and after Wii sports begins I have to put the TV on mute as the TV audio continues as before I got trhe Wii going. Does not seem right.
MikeI need to know if Wii comes with sound. Mine does not. I am plugged into the TV front and after Wii sports begins I have to put the TV on mute as the TV audio continues as before I got trhe Wii going. Does not seem right.
what colour cables are plugged into what devices? If you are using the standard (at least in Australia) video cable it will have 3 plugs, yellow for the picture and Red and White for Audio.
Those red and white leads need to be plugged into something that can receive a stereo signal, like most likely your TV or a stereo system. what colour cables are plugged into what devices? If you are using the standard (at least in Australia) video cable it will have 3 plugs, yellow for the picture and Red and White for Audio.
You can't post conmments that contain an email address.
Maybe your RGB plug is damaged. (Your Yellow-Red-White Plug) And try to reset the Wii, this will reset everything + the audio settings of the WiiMaybe your RGB plug is damaged. (Your Yellow-Red-White Plug) And try to reset the Wii, this will reset everything + the audio settings of the Wii
I had this problem too, and I found out what was wrong. I hope it's as easy of a fix for you as it was for me, the only thing is if the reason is the same. If your Wii sensor bar is not wireless, carefully check the wire for frays. Once I brought my Wii to my cousin's house and had the same problem you have. We did everything we could think of, then I checked the wire. It was frayed. I couldn't understand how it happened because we barely ever touched it, but we just replaced the Wii bar and everything was fine. Even if you can't see any frays on the outside of the wire, it's possible that the damage is on the inside of the wire. Try testing another wii bar on your system if this happens or if you don't find any visible frays. I hope this solves your problem. I know how frustrating this can be. Let me know if everything worked out!
We ended up sending our Wii to Nintendo of America. They were quick to repair it. Actually, I was pleasantly surprised how good the service was. You have to login to the Nintendo website and report the problem. If your Wii is registered and under warranty, they will send you a prepaid shipping label. You sent the console in, and they ship it back. The whole thing took about a week. The website allows you to track the repair and shipping process.
Press and hold the sync button on the Nintendo Wii remote. While holding the sync button, go over to the Nintendo Wii, and and press and hold the sync button. Wait for a few seconds, and then test the Nintendo Wii remote.
Mike
