Need help hooking TV back up after move. Connecting to Dish Network Reciever/DVR getting No Channels in List message when on Tuner, all other inputs are indicating No Signal
Re: Need help hooking TV back up after move. Connecting...
It is so hard to explain by over a few words. The best solution I have for you is remember this. What goes out from a device must goes into a device. A in device would be (television)
I realize this but why is it not working ...when it was just a few hours ago. The kids watched Dish earlier today and then we watched some Netflix show and now when I turn back to the channel I have the input for my Dish it won't workI realize this but why is it not working ...when it was just a few hours ago. The kids watched Dish earlier today and then we watched some Netflix show and now when I turn back to the channel I have the input for my Dish it won't work
You can't post conmments that contain an email address.
Is TV 2 off the 322 receiver being back fed from the receiver or do you have a direct connection to the 3rd room? If it is a direct connection, you would screw the coax from the 3rd bedroom directly to the TV 2 Home Distribution channel 21-69 out port.
If you are back feeding, you need 2 diplexers that connect 1) by the receiver and 2) between the receiver and the 3rd TV. The back feeding will use the same cable coming from the dish to the receiver.
If you have any other questions, please don't hesitate to ask.
To watch Dish Network in your room there a couple of different ways to do it. Unless that cable coming out of your wall is connected to a Dishnetwork reciever its useless.Now if the reciever in your living room is a dual tuner dvr than you can run a cable from one of the two outputs to your bedroom. In this scenario you can watch different channels at the same time. If it isnt a dual tuner then you can actually put a splitter on the cable coming out of the box to the tv(has to be on cable coming out of the reciever) and run it to your bedroom. In this scenario both tvs will show the same channel.In both cases you need a UHF remote(dual tuner DVRs come with one UHF and one infrared) that will allow you to change channels while in your bedroom. If you want HD programing on both tvs you will need to contact Dish Network to get a second reciever. its $7 more a month for a second reciever.
Hello, my name is Daniel Busa with Dish Network customer service. Whats probably causing the issue would be that either you're not getting high enough signal strength on the 61.5 satellite. Otherwise there could be an issue with the box if you swap it with another reciever in the home, and the issue follws it you'll need a new box.
Hello! Dan Busa here with DISH Network customer service. This is actually how your DVR is supposed to function. A 622 is a dual tuner reciever meaning it's capable of watching or recording two live shows at a time. When you record a show you tie up one tuner, there are two work arounds. You can get an additional dvr receiver or you can set up record preferences and have everything automatically record to tv2.
dvr's record from the signal input, not from the tv. tv's are just used to display.i expect the input from ariel? sat dish? freeview box? is not connected right
You can not change channels on Satellite with your TV tuner card. The satellite box decodes the sat signal (it is sent encrypted) you can run S-Video/RCA/HDMI depending on the video card input, but you will be required to change the channel on the Dish box. The TV card can only change channels on broadcast (over the air) channels, you can attach an antenna and it will use the NTSC tuner to change analog channels (if they are still available) and the ATSC tuner to change digital/HD broadcast channels. This card (from your description can ONLY deal with broadcast TV, You will need a TV card with a QAM tuner for unscrambled digital cable. There is no solution for directly interfacing with Satellite on a PC or Mac (DirectTV or Dish) the signal from the satellite is encrypted and requires (at least for DirectTV, a fairly complicated decryption setup to function, this is handled by the tuner box/card combination. Sorry your setup will not support changing the channel on the PC, you may be able to find some kind of software that can utilize an IR transmitter to change the channels on your satellite box, similar to the way a Tivo or other DVR can talk to cable boxes, but that is the best you will be able to do as far as channel changing.
Use an RCA audio/video cable for this set up (Yellow/Red/White).
Connect from the Video out (Yellow) connection on the back of the cable box to the Video in on the back of the DVR.
Connect the audio (Red/White) cables from audio out connection on the back of the cable box to the "Audio in" on the back of the DVR.
This should still get you a decent picture but not a true HD picture for your recordings.
When you set the timer to record set it to record either E1 or E2 depending on which input you connected the cable box to and ensure that the cable box is tuned to the channel you wish to record.
*** NOTE: If you keep the HDMI cable connected as you have for the cable box and watch normal TV through the HDMI input on the TV you will get HD programming for your general viewing but still have the option to record with the DVR at a lower quality. ***
You will need to run a set of audio cables from the TV1 output on the rear of the 625 directly to one of the three audio inputs on the surround system. Thanks for using Fix Ya.
I am probably stating the obvious here but here it goes:
If the 625 is connected to the tv using coax directly try using the RCA jacks to connect directly to the tv. If the 625 goes through a peripheral first, eliminate that peripheral and conect directly to the tv.If the problem exists with different media connections still at the same tv you can remove the coax off of the TV1(3-4) output on the back of the 625 and attach it to the TV2(CH60-73) output.You would then change your tv channel from 3 or 4 to ch 60air or 73 cable(which will be the same channel that TV2 is normally on in the remote room without the 625) Once you are on the right channel you will be able to tune TV1 to your local channel using the TV2 remote. If the audio is good here it eliminates the TV coax input on the TV1 and the coax cable connecting it as the source of the problem. You will have already eliminated any other inputs on the same tv as being faulty by using the other connecting media leaving you with the internal components of the receiver as being faulty. In this situation I know of no recourse except the obvious.
Kingscott,
Make sure the cable connection from the dish to the tv is
connected to the antenna/cable input and not the digital
input. Turn on the satellite receiver then auto program the
set with the receiver still on. If this fails to lock in channel
3 your suspicion regarding a faulty tuner could be correct.
A good way to check the tuner operation would be to hook
up another product such as a VCR with the rear switch set
for channel 3 and see if you can receive a picture from this
device. If it works the tuner is OK.
You can bypass the tuner by connecting an S-Video cable
and (or) a set of A/V (yellow,red & white) cables from the
output of the satellite receiver to the video 1 input on the tv.
You'll then have to switch the tv source mode to video 1.
Hope this of some help,
Caseybee
