NorStar CallPilot 100 Logo
Posted on Nov 23, 2009
How do you find all of your mailbox numbers in the
How do you find/list all of your assigned mailbox numbers in the norstar voicemail system
terry gormley
Level 1:
  • Contributor 52 Answers
  • Posted on Jan 04, 2010
terry gormley
Contributor
Level 1:
Answers
52
Questions
0
Helped
44942
Points
82
Your mail box numbers are usually the same as there locals
Why would a NorStar StarTalk suddenly stop accepting voicemail calls?
"Q: My Norstar Startalk, Flashtalk, or voice mail says my mailbox is not accepting any more messages. I deleted all my messages, but callers still cannot leave a message. Why?
A: Check with your voice mail administrator. Chances are another Mailbox on the system used up all the message storage space. Usually it's the general delivery mailbox that hasn't been checked for messages on a regular basis."
Frequently Asked Questions
The following discussion suggests that voicemail can be inactivated, and cab be re-activated by logging in and pressing '4'
Startalk Flash Won answer Nortel Phone System Tech Support
This says that the mailbox must be initialized.
http://www.uniquecomm.com/docs/Startalk_Flash_Quick_Reference_Guide.pdf
Voice mail locked after various attempts at putting wrong password in. How do I rectify?
Your mailbox is assigned a maximum number of incorrect password attempts.
Norstar Voice Mail records the number of incorrect attempts from the last time your mailbox was successfully accessed. Once the number has been passed you are"locked-out" Your mailbox cannot be opened again until the System Coordinator resets the password
4helpful
When logging into the voicemail for a Nortel T7316E i get the Mbox Locked warning. I have followed the steps to reset my password and have successfully done that. I then proceed to access my voicemail with...
You're resetting the wrong password. Keep in mind that mailbox numbers and extension numbers are not always the same. When you're resetting the password, make sure that the EXT assigned to it is the right one !! If you're resetting the reception mailbox, it's usually mailbox 100 (regardless of what the extension number is)
1helpful
Trying to listen to voicemail grettings.
If your talking about listening to the individual mailbox greetings without calling into the system then you could use feature 980 (leave message)
enter in the mailbox number you want to check and press ok.
My phone is Norstar M7324. I can't get voicemails. I have customers called and left voicemails but I can't receive them. I use Feature 981 and it tells me no messages everytime. Any advise? Thanks.
Maybe the callers are leaving messages in the General Delivery mailbox? From your phone, dial Feature 981, when it prompts you for a password, press the button under "OTHR", and you will be prompted for the log. (The log is the mailbox and password combination for a mailbox not assigned to your phone.) If you use 2-digit extensions, the General Delivery mailbox is #10, for 3-digit extensions, the mailbox number is #100, and etc. The default General Delivery mailbox password is "0000". So, using 2-digit ext's, the log would be 100000, then press # or OK and you can retrieve the messages. Write back if you need more help.
9helpful
We have Nortel T7316. I have been locked out of the voicemail admin. I have tried all passwords I can think of but cannot get in. Please help
How do I reset a password on a Norstar Voice Mail mailbox?
Press Feature 983.
Enter the System Coordinator's Mailbox number (default is 12, 102, 1002, depending on length of extension numbers) followed by Password (default 0000).
Press MBOX.
Press CHNG.
Enter the mailbox number that is giving you troubles.
Press RESET. The password has been reset to default (0000).
Good Luck.
1helpful
Unable to add voicemail box on Norstar system
If the mailbox is made, you need to check the programming under sets, FWD no answer, that needs to forward to the extension on the voicemail.
3helpful
3answers
My phone on our Norstar system rings & rings & never goes to voicemail. Other sets on this system ring 4 times & then automatically go to voicemail. How do I cjange my set?
Fress F985 u will get voicemail DN. Note down ur voice mail DN.
Go to programming of Norstar which will be F**266344 password will be 266344.
Dispaly shows u terminal and extensions.
press show
then next display will show u capabilities.
Press show then next display will show u FWD no answer.Press show then change put the voicemail Dn which u had written then next.
Now call will go to ur voicemail provided u have ur own presonal mailbox. If it is not there u will have to createe it otherwise it will go to general delivery mailbox.
Hope it will be helpful for u.
Thanks.
1helpful
How to chg a norstar mailbox from 'General Delivery' to 'User'
check under the mailbox set up ( where you created it) for that extension that the extension number of that phone is on that mailbox> in other words, you could create mailbox 221, but assign it to 222. The Gen Delivery box is 100 which is the catch all for transfers that cannot be completed.
2answers
Voice Mail
if you can not transfer a call to voicemail, there isnt a mailbox made. If you transfer a call and it doesnt go to voicemail, then there isnt a mailbox OR it isnt assigned to the voicemail group.
To assign a phone to go to voicemail (if there is a mailbox made)
at extension 10 or 11
press feature 00
LEFT intercom
Left intercom
#310 (auto VMS cover)
group 7
enter extension number.
If it says 2 not assigned, press "1" so it says assigned.
Press feature 00 when done.
If it still does not work, you need to build a mailbox. Will need to know EXACTLY which voicemail it is in that case.
Top NorStar Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a NorStar Computer and Internet Expert? Answer questions, earn points and help others
