The waher cyclewill finish but the water will not drain when it is time to drain and spin
Draining problem is very common in Bosch washers. However, it is very easy to fix.
1) Remove the white circular plate, located on the bottom left. Push a small screwdriver or needle through it and simultaneously rotate the plate clockwise.
2) Open the drain valve. Rotate the circular black handle counterclockwise. Beware of residual water.
3) Clean it. Re-assemble in reverse order.
Thanks for contacting fixya.com
