Texas Instruments TI-83 Plus Calculator Logo
Posted on Nov 23, 2009
When i turn on the calculator i get a dark screen and when i try to adjust the con trast it doesnt change
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 23, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
166
Points
This is what i think you mean, if i diss-understood you (thought you mean something else) im sorry, then i dont know what to do
thats when you set your ti 84+ screen to very dark. this is how to solve it:
go and open mirage OS, and then just press the "-" (minus) button. the screen should get lighter.
My calculator just won't turn on. The batteries are brand new and I used the calculator for only 1 quarter and it's been sitting in my room all summer and now it won't turn on. what do i do?
Okay; Have you tried adjusting the contrast? This is a common problem with Ti calculators. Try pressing 2nd and up. This will darken the screen. If the screen becomes too dark press 2nd and down to lighten it. Happy Calculating
3helpful
Screen was too light and I changed the batteries. Now it's too dark. How do I adjust?
Turn the calculator on. Press and release the 2ND key. Press and hold the Down-arrow key.
2helpful
I replaced the 4 AAA batteries and it won't turn on do I have to replace the back up battery as well? Thanks
There is a strong probability that your calculator is functioning correctly. The problem is that after replacing main batteries the screen contrast may become too dark or too light (your case).
To fix this "problem" you must adjust the contrast.
To darken screen:
  1. Press [2nd] key and release it.
  2. Press and HOLD the UpArrow
  3. Keep pressing UpArrow until screen is dark enough.
Try this adjustment. I am confident it will bring your calculator to life.
If it fails, post a comment to this thread and I will give your additional diagnostic procedures.
8helpful
Cannot read screen - screen dark nocnotrast just
To adjust the contrast, turn the calculator on. Press and release the 2ND key. Press and hold the Up-arrow to increase or the Down-arrow to decrease the contrast.
1helpful
I have a TI 84 plus silver edition. Won't turn
The problem may be due a screen that is too light to see anything on it. Adjust the screen darkness.
  2. Press and HOLD the [UpArrow] to draken screen.
  3. Release the [UpArrow] when screen is dark enough.
You can also connect it to the computer to see if TI Connect finds it. If it does, update the OS to version 2.53MP.
You change the backup battery if the calculator tells you RAM CLEARED each time you turn it ON.
3helpful
The screen is black when I turn it on. I've replaced the batteries and no change. I try to change the contrast and nothing happens. It is a couple years old, but I should still work.
Check that the terminals in the battery compartment are clean and shiny. Remove any powder left after battery leakage. Insert fresh batteries in calculator. Make sure you respect the polarity diagram. +-+- (Many malfunctions come from incorrectly placed batteries).
To adjust the screen: Darken or lighten display
To darken screen
Press and hold [UpArrow] until screen is dark enough.
To lighten screen
Press and hold [DownArrow] until screen is light enough.
Hope it helps.
3helpful
TI-83 screen is black
The "color" on your screen reset to dark. You can adjust it by pressing "2nd" and the "up" arrow (or "2nd" and "down" arrow) repeatedly.
When I turn on my calculator, every pixel on the screen is dark?
try pressing 2nd-> "up arrow" to adjust the contrast, keep doing it and it may solve ur problem
TI-89
Did you try [left][right][2nd][on]? It reinitializes the memory and clears the ram.
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
