Sharp AR-M162 All-In-One Laser Printer Logo
Posted on Nov 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Network error CE-02
Our machine was recently moved to a different connection on the network. Whenever I try to scan I get the message: Network error Please see network administrator CE-02
Anonymous
Level 3:
President:
  • Master 1,865 Answers
  • Posted on Nov 23, 2009
Anonymous
Master
Level 3:
President:
Answers
1865
Questions
0
Helped
599419
Points
5720
You didn't tell me enough about the problem. Are you trying to scan from a PC or to a PC? The problem is that the network address changed when you moved the printer. You can fix this by correcting the network address
I have a Sharp AR-M550N; It's giving me a code Network error CE -02? How can i solve that error?
CE 02 is rarely a machine problem, It normally is an addressing problem between the machine and the network. That code indicates a communication problem, normally relating to scanning.
Often times it is a wrong character in an address.
1helpful
What is Network error (CE 02) thank you
Network Error CE-02 - this is where the machine cannot communicate with the SMTP Gateway / Mail Server for scanning. Check that you have a connection with the network and that you have the correct SMTP I.P address.
If you are using a host name for the mail server make sure that you have configured the DNS entries correctly.
Hope this helps.
Our machine is a Sharp AR-M55OU and it is giving us the error CE-02 when we try to scan. What does that mean?
I believe the CE-02 is a generic network error.I had the same issue, with us it was a DNS issue. We had old computer accounts in DNS confusing the scanner when using hostname. Have your network admin scrub DNS and see if it solves it.
Sharp AR-BC260 shows the network error CE-02
You need the Sharpdesk Software CD and you will have to install it in order for the scanning function to work.
Getting a CE-02 error when trying to scan.
1) Check that the Network Cable is
inserted properly.
2) Check that the connected network
supports TCP/IP protocol.
3) Check from the Web Page that the
Primary/Secondary E-mail Server
Address or the Destination FTP server/
Desktop PC address are properly set.
4) If the above address is described with
Hostname, check that the DNS server
is properly set.
5) Check that the SMTP server/FTP
server/NST causes a trouble or not.
2helpful
3answers
Error code CE-02 when in the scan mode.
the FTP server cannot be found. This is a network error. If it is connected to a network, check with your IT person to set up the FTP server.
Network Error code CE-02
the ce-02 code is just a communication error it general in nature so you could have a couple different issues going on
1helpful
Network Error CE-02
There is a Windows Port that is being blocked. First make sure the IP it's scanning to and IP on the machine are the same. disable the firewall. I'm working on narrowing down the port now and will post as soon as I find it.
-Mike
15helpful
10answers
Network Error CE-02
Error ce-02 means that the computer the image is being sent to is not running sharps "network scanning tool" which is part of the sharpdesk software suite
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_0c6af8f6331df718
2answers
Network Error on display
Have you setup your smtp address on the machine? From any workstation in the same network open your web browser. Key in the IP address of the mfp copier. Goes to network setup and key-in your smtp address.
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
