Question about Motorola Mobility RAZR V3x Cellular Phone
Put in sim aske a code wrong then contact operator popped up ?
I slip the sim card and opened it I waqs asked subsidy code which was entered wrongly and now it displays contact operator and cant find anything in the settings wen i place the old 3 mobile sim card
  • Motorola Mob... Master
  • 32,281 Answers
When you place a new or a existing SIM card from another phone provider into your mobile phone and it asks for a Security code then :-
This phone is locked to the original mobile phone provider. You need to contact this mobile provider to ask for the unlock code (security code) for this phone. You need to provide proof of ownership etc and the phone's unique IMEI number which is located inside the phone under the battery. They use this number to generate the unlock code for your phone.
They should provide you with instructions on how to enter this code into the phone.
Once you unlock the phone, then you can insert a new SIM card in this phone or sign up with another phone provider using this phone.
Posted on Nov 23, 2009
SOURCE:
Subsidy password for motorola w490
The term Subsidy Password is used by Motorola and other handset manufacturers to refer to the 8-digit (or 16-digit code for newer phones such as the Motorola K1) unlock code necessary to remove the operator lock (also known as subsidy lock) from cell phones. This code is randomly assigned to individual cell phones by the OEM on request of the mobile service operator and prevents the use of a particular phone on a cellular network other than that to which the phone was originally sold.
To get the Subsidy code You can reach here
Mobileunlocksolutions.com enter the code correctly following the instructions below:
Warning : Do not enter any wrong unlock codes on your Motorola W490 mobile phones. If you enter over a certain amount of wrong unlock codes on your Motorola W490 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Motorola W490 with a NOT ACCEPTED SIM Card,
2 - Phone will display "Enter Special Code",
3 - You can now enter the Unlock Code.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Motorola W490 is locked to.
WARNING: If one of theses messages appear :
- "Contact Service Provider"
- "Tampert Alter"
- "Wait before enter special Code"
- "Contact Service'
Aug 24, 2011 | Motorola Mobility SLVR L7 Cellular Phone
Hi my sons phone is showing enter PUK code! can you help or do I have to contact his network/supplier? thankyou
PUK code stands for pin unlock code. It comes when you enter wrong code for your pin code three times. It is a security feature of your sim card to avoid unauthorised access.
When you enable pin code on your sim card, your phone automatically asks for pin no. when switched on. If the pin is entered wrongly 3 times. It locks the sim, and asks for PUK code. The PUK code needs to be obtained from your provider. If you enter PUK wrongly 10 times, your sim card will be permanently blocked and you will need to obtain a new sim card. Hence kindly contact your network for the right puk code.
Jul 20, 2011 | Cell Phones
Iv put my wrong pin code in my 3sim an need the puk to unblock it can u help me
the following codes are provided by the network operator:
-pin code
-puk code
both of these codes are provided when you purchase a sim card and are usually written on the sim holder or on the provided booklet.
if u have the puk code, then u can enter a wrong pin multiple time and then the sim card will ask you for the puk code which then u can use to unlock the sim.
if u lost both the sim and puk, then the only way is to contact the network operator to give you a new sim card.
Don't try to enter a PUK code without knowing the right one.
hope this helps
Mar 11, 2011 | Cell Phones
When i put my sim in it asks for an unlock code?
It is asking for code because you change your sim card security when you insert this in phone last time. It is asking for PIN code. Only network service provider know this code, contact customer care of your service provider. If you entered wrong PIN number three times your sim card will be rejected hence don't try to enter wrong code.
Feb 07, 2010 | Lands Phones
Subsidy lock on my i870 nextel
If you enter wrong password for more then 5 times,it ll ask you to enter the puk number....now call your customer care and
get the puk number...enter the puk number in the space given for password....thats it...problem is fixed
If you had locked your mobile then update the formware all saved passwords will be deleted.
OR if you contact your customer care they will unlock from there.
Hope I`ve helped...
Nov 22, 2009 | Motorola Mobility i870 Cellular Phone
Ive forgot my pin and have smsd 3 times and no response
When you enter PIN code 3 time wrong, your phone is asking for PUK code. When you enter a PUK code, the phone will ask for new PIN, you should tipe some 4-digit code which you will remember, then verify them. After that your sim card is working again. Caution: Be carefull if you enter a PUK code 9 time wrong you will crashed your sim card and then you must contact your network operator for information about replacement your sim card. PIN and PUK code is coming with your sim card, but if you didnt keep that you also need to contact your network operator about your codes.
Nov 11, 2009 | Lands Phones
MObile shows contact operator
check your phone setting
it may be locked and it has to be unlocked
check your connectivity
Sep 26, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Sony Ericssion K520 is blocked and asking PUK code
When you purchase any new sim card then a PUK code prints on this card holder. You can also call to the service provider to ask PUK no of your sim card. After enter the PUK no. your phone lock will be open.
Sep 24, 2009 | Sony Cell Phones
Free unlocking or subsidy code for mobile phones
You could ring the phone provider and ask for the unlock security code because you are going overseas and wish to use your phone with a prepaid SIM card from another country. This maybe a free service.
The other way to get your phone unlock is to use a phone unlocking company on the Internet, they usually charge a couple of Dollars for their services. Use Google and search for "Security unlocking code” companies in your area.
Feb 15, 2009 | Motorola Mobility RAZR V3
Trying to install an AT&T prepaid SIM on a T-mobile phone (motorola razr)
Unfortunately, you can't reset without the subsidy lock code.. sorry.
Feb 08, 2008 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3x Cellular Phone Logo
140 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
