Buy a universal USB cord which has many different connecting ends. Easily available in electronic shops. Connect USB 2.0 to the pendrive and the other end to JBL IPOD dock
Details:
The second
generation iPod nano models are capable of charging and syncing by USB via
the dock connector. It also can charge, but not sync via Firewire
"400".
Connectivity:
USB
Ports:
Dock, Headphone*
Details:
Apple reports that this model provides "USB through
dock connector."
To charge the battery using your computer:
Connect iPod shuffle to a high-power USB port on your computer using the included
iPod shuffle Dock. The computer must be turned on and not in sleep mode (some
models of Macintosh can charge iPod shuffle while in sleep mode).
When the battery is charging, the status light on iPod shuffle is orange. When the
battery is fully charged, the status light turns green.
If you don't see the status light, iPod shuffle might not be connected to a high-power
USB port. Try another USB port on your computer.
To charge the battery using an iPod USB Power Adapter If you do not have then you have to buy the same from Apple Store)
1 Connect the AC plug adapter to the power adapter (they might already be connected).
2 Plug the USB connector of the iPod shuffle Dock into the power adapter.
3 Plug the power adapter into a working electrical outlet.
4 Put iPod shuffle in the dock.
You can disconnect and use iPod shuffle before it is fully charged.
hi, there are no provision for connecting ipod. u can connect onlyusb mass storage devices through ur tvs usb. if ur ipod comes with an usbchord just connect it to the usb port of ur tv and then select usb. normally if tv has an ipod connectivity it will comes separate connection for the same, and there will be an ipod dock( optional accessory u have to purchase it separately ) . ok
i need to connect my ipod docking device to my laptop in order listed my music from the laptop louder throygh the device.
i bought a usb cable in order to connect the lap top to the jbl device ?
If you're willing to spend $40, there's an adapter available from Scosche Accessories. It comes in both black and white and they say it will convert any docking device to the new charging format. (The problem is that Apple has discontinued charging via the FireWire pin - which virtually all accessories - even including Bose - have used up to now. All the 2nd Generation stuff now uses direct USB charging, not FireWire.
This compatibility issue is caused by the same change with the Apple
Dock Connecter introduced with the iPhone 3G. Inside the iPod / iPhone
Dock Connecter are 30 metal pins. Previous iPods and iPhones allowed
for charging either over pins reserved for the USB connection or pins reserved for the obsolete Firewire connection.
While
Apple apparently announced this upcoming change to manufactures of
“Made for iPod” accessories back in 2005, Apple only formerly
discontinued Firewire charging support with the most recent iPods. New
iPods and iPhones can only charge via the USB pin.
As such, there is no way that a software update can fix this issue in the future; this is truly a modification in iPod hardware.
USB device not recognised" - means windows needs driver to function. As soon as you connect USB device it check driver in cache it is available it detect smoothly you can perform else it generate errors.
