Question about Electrolux EW1000i Front Load Washer
My electrolux IQ Touch came up with error code E13 first time using it what does this mean
    New Friend:
The solution for E13 is to unplug the Electrolux washer for a few seconds (10-15 seconds) then plug it back in and press cancel. Then it should reboot itself. It's some problem with the computer which just needs to be reset
Posted on Dec 27, 2012
3 Suggested Answers
SOURCE:
abhishek33
  • 1239 Answers
SOURCE: Washer lights are all flashing
Hi friend.....
It is an indication of an error code,,,,,,,did you see any error code on timer.........
thank u..........
Posted on May 03, 2009
SOURCE: i lost my manual for
Here's a link to the manual:
http://www.electroluxappliances.com/Files/Documents/Use%20and%20Care/EIFLW55H_uc_EN.pdf
Posted on Aug 23, 2010
E13 error code on my electrolux washer what does it mean
You didn't specify model of your washing machine.
For Electrolux that usually means water leaks (Maximum overall water fill time exceeded (sum of all water fills between one drain phase and the next to avoid exceeding the maximum volume).
Could be:
Drain tube improperly positioned; Water pressure too low;
Water fill solenoid valve faulty; Water circuit on pressure switch is
leaking/clogged; Pressure switch faulty.
Dado
Mar 03, 2017 | Electrolux Washing Machines
Electrolux E13 error code
The "E13" error code on the WFMC series Bosch washer`s refer to a drainage problem as you may or may not already know. ( or in Bosch terms "pump time exceeded" ) What you may have is either a clogged pump, improper detergent being used, ( must use "HE"/lo-sudsing detergent ) hence suds not allowing a proper drain cycle, or wires loose at the pump...the later being the least likely. You haven`t mentioned if you`ve checked the pump...just hoses as you did mention. Anyway, here`s the most likely way to remedy a E13 code. **Unplug the washer from the wall or turn off the breaker before attempting any repairs** Get some towels and if possible a wet/dry vac. If the machine drained, it won't be too bad. If your machine is stuck full of water, I can't say, hopefully you won't get wet. ( maybe you`re lucky enough to be close to a floor drain ) Locate the round door on the front of the machine (about 6" in diameter, lower right corner) Find a drill bit or small screwdriver that fits in the hole in the round door. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free. (the edges are very sharp so be careful or wear chain-mail gloves). Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand. ( you should also see a red ring with a string attached, if you pull this the door should unlatch, but getting the water out first is usually a good plan ) There is a small collector lip at the bottom of the cap, that is where you can hold the wet/dry vac to catch the water. Unscrew slowly so you don't get flooded, until it is unscrewed all the way out. Now pull out the trap and visually inspect the inside of the pump as well as the filter/trap. Hopefully you'll find the item/debris that initiated the error code. After removing any debris or obstruction`s re-install the button trap/lint filter and plug the washer in to power or reset the breaker and give it a test. Run a load and watch for leaks. Leave the pump access door off until you are sure you screwed the cap in tight and there are no leaks. Ultimately you may have a faulty drain pump, but I would certainly start by performing the things I listed first. Let me know if you require further assistance and if not and this indeed solves your problem, please rate the solution I provided accordingly.
Sep 12, 2014 | Electrolux EIFLW55HIW Front Load Washer...
What is electroklux washer code E00
Hi friend, thank you for your inquiry!
On an Electrolux washer the error code "E00" stands for No code stored. This could be a miscommunication I would recommend you perform a reset on your washer. You can do this by flipping the household breaker for roughly ten minutes. If resetting the power does not correct the issue, could you please inform me of the new error code or if your washer continues to display "E00". I look forward to assisting you. -Matt
Aug 14, 2014 | Electrolux EIFLW55HIW Front Load Washer...
What is error code e13
Good Afternoon Friend,
I understand that you are receiving an E13 error code on your Electrolux washer, model# EW1000i. In researching the model number you provided, I show that this was manufactured in the UK. For North American washers, I would suggest resetting you appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. You can try this, and if it does not work, I suggest contacting the manufacturer directly, for further assistance. They should be able to tell you what the E13 means, as well as assist in clearing it. Hope this is helpful.
-Best Regards-
WP
May 31, 2014 | Electrolux EW1000i Front Load Washer
Electrolux EIFLW55HMB Front-Load Washer With IQ-Touch controls won't open
Try unpluging for a few minutes . wake the washer up by turning knob then at the same time press and hold start cancel error will display . take off top and you will find a tech sheet on left side and that should help. you can manually unlock the door after taking top off and reach down to door lock you will feel a plastic switch to pull
Feb 17, 2013 | Electrolux EIFLW55HMB Front-Load Washer...
How do i reset an electrolux 1080
E20 is an error code for a drain pump issue. The error will reset itself if the issue has been resolved. If it or another code continued to appear, then the unit has not been accurately fixed.
Jul 19, 2012 | Electrolux EIFLW55HIW Front Load Washer...
WHAT IS THE FIX FOR ERROR CODE 21? THANKS
Hi.
Code E21 means that there is a drain problem. The repair is carried checking the drain hose at the back and accessing the drain filter (in front at the bottom with most machines from those manufacturers. IF there is no problem with drain lines then the pressure switch , the pump or the electronic control may be responsible. For some general troubleshooting see : My washing machine does not drain.
Regards.
Ginko
Aug 30, 2011 | Electrolux EIFLW55HIW Front Load Washer...
Hi friend.....
thank u..........
May 03, 2009 | Electrolux EIFLW55HIW Front Load Washer...
Error code E10 on the electrolux ecovalve EWF1087 front load washer. What does this mean?
E10 is a timeout code. I found the answer on google by refining my search criteria. The tap was not turned on enough for the washer to fill up in time before the timeout was reached. After restarting the washer and turning the tap on further, the washer cycle completed without error.
Jul 22, 2008 | Electrolux Washing Machines
Electrolux EW1000i Front Load Washer Logo
2,492 people viewed this question
Top Electrolux Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Poppa Maddo
Poppa Maddo
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
