You may need to calibrate the incline. Do this with the following procedure.
Safety key out
press the stop and speed up buttons at the same time while inserting the safety key. (you are now in diagnostics)
press the stop button one time only.
now press the incline up button (incline motor should start moving up)
incline will go up to the top and then all the way to the bottom. when it gets done you can remove the key. Reinsert the key and you should be operating normally.
Good luck Tim
I tried this recalibration on my proform 730CS without success. I entered calibration mode fine, but the incline did not move at all - just beeped. What else can I check?
I have the same problem as referenced above and had the same outcome when applying the re-calibration procedure. Other than replacing the mechanism what else can we do?
When I turn on the Treadmill (Pro-Form XP 550s) the incline starts jumping up and down like it is slipping. It won't do anything else just keeps jumping.
Put the key in and turn the incline to top setting (usually 10%) and as soon as the incline starts pull the key out, resetting the system
SOURCE: will my ifit treadmill card work in an incline
Technically, the Incline Trainer and the treadmill are two different type of machines. The incline trainer raises much higher so the card that is designed for the treadmill will not work on the incline trainer unfortunately.
o The Nordic Track C2050 allows users to change the incline of the treadmill with a simple touch of a button. This treadmill features both increase and decrease buttons for the incline. The incline of the machine will change by .5 percent every time the buttons are pressed. With each press on the incline buttons, the machine will take a moment to actually reach the incline setting that was just selected.
Capacity of Weight
o Users who are larger than or weigh more than the average person will be pleased with the added capacity of weight that the Nordic Track C2050 allows. Unlike most treadmills in its economy class that only allow a weight limit of 200 to 250 pounds, this model lets users who weigh as much as 300 pounds use the machine safely. Larger people can get the benefits of a cardiovascular workout on this treadmill without worrying about damaging it.
Heart Rate Measurement
o This Nordic Track model allows users to measure their heart rate. All the machine requires is for users to place their feet on its foot rails and grasp the metal contacts with their hands. The Nordic Track C2050 then works to determine your pulse, and the symbol of a heart will eventually show up in the display. After a couple of dashes show up, your heart rate will be displayed. Users who want to be certain of getting an accurate reading should ensure their hands are clean when gripping the metal contacts.
sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Thanks for the advice, I was able to do what you said and on the first try my treadmill started working.
-JLicea
