Televison & Video Logo
Posted on Nov 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Trying to install channels on goodmans ld1962d. Not sure what active antenna is. No channels are found when we have aerial in or out.
Joaquim Martins
Level 3:
Genius:
  • Master 1,128 Answers
  • Posted on Nov 22, 2009
Joaquim Martins
Master
Level 3:
Genius:
Answers
1128
Questions
0
Helped
298260
Points
3333
Check for antena cable plug condition, normaly 80% of low quality of antena signal, is conection on antena plug (inside)
1st open antena plug, check for condition/connection of cable.
2nd check for each part of cable well connected, and no wires crossed on middle cable
3rd check same to the other end of cable.
4rd check the signal on diferent tvs around house (if available)
if this general you dont have aerial signal in your house, check for your TV provider (cable) to test your arial signal.(Normaly this maybe a cable broken outside house).
I have an indoor digital aerial connected to a free view box but when I automatically tune the TV it comes up with no channels found check aerial connection
Possibly. Try rotating the antenna a little bit and retry tuning. Keep on doing this until you get your channels. If this doesn't work, raise the antenna as high as possible and try again.
2answers
Why can't we get a channel of our bought television?
First, is the antenna to which your TV is hooked up working? Are the other three on you block receiving TV channels? The signal from the antenna has to be split four ways, so you need to use a four-way signal splitter and probably a signal booster/amplifier. It is probably wise to have a professional TV antenna installer at least access your setup and make suggestions.
Trying to tune in my t v 37722hd no manual
If you are connected to the sets coax or cable fitting and not using a box go into the customer menu for set up and select antenna if using antenna and not cable.
With set hooked and on in menu find autoprogram and engage it.
If no channels found use remote and directly with keyboard enter a channel like 03 and see if reception.
Let me know what is connected and what you have tried. A brand and confirmation of the model number would help.
I have a Goodmans GTV26W3LCD TV. I have moved to another room on a similar aerial, but cannot get more than 2 out of the 5 basic channels.The channels give a good picture,I do not seem to be able to get...
The antenna has everything to due with reception.
Try moving it to a different direction or try a new antenna altogether. It's also possible that the three stations are weaker than the other two and the new room is blocking these signals more. It this case you would need to use an external antenna to retrieve the the signals.
1helpful
2answers
Hello .i have a lg tv which i purchased in 2008 and only watched videos,i now want to watch tv i have tried auto tune and it only finds 3 vhf channels and none digital.it has preview built in but i can not...
if it has freeview built in its usually programmes itself try turning it on and go into the menu and there should be an auto tune function hit that and it should tune up but remember it needs to be connected to an aerial if it still says no signal try moving the aerial, getting a booster for the aerial they usually plug into the mains then into the back of your tv and you plug your aerial into that to boost the frequencey if that doesn't work then you might need to think about getting a new aerial but you can get 1 for under £30
Cant get any itv channels after retuning my new tv because of bad reception on itv channels.its a new aerial and the tv in other room ok its HITACHI 26ins L26HPO3U
in the manual i noticed a note about the active antenna and it should be showing not active when standard antenna is used.i also tried channel scan instead of first time installation which i tried a few times.so i dont really know which worked,just kept trying.
2answers
Goodmans GTV69RFDT Television had all freeview now only getting 3 channels
First ensure that the TV input is set on the Freeview channels, just in case.
Then check the antenna, when Freeview does not get all channels, it is always the aerial (antenna).
Many areas in UK have still poor reception. If you use an internal antenna, go to Argos or Currys and buy an amplified antenna for freeview, that will improve the signal.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
