Leviton COMBINATION SINGLE POLE TOGGLE SWITCH Logo
Posted on Nov 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a fan the is connected to 3 switches. If one switch is on the other switches no longer work
Anonymous
Level 3:
  • Master 10,865 Answers
  • Posted on Nov 22, 2009
Anonymous
Master
Level 3:
Answers
10865
Questions
0
Helped
3798995
Points
33142
Hello. I can help you. Assuming that all three switches used to work and now you have this problem, you have a switch that is worn out or has a wire that has come loose.
Turn off the power to this fan and open up one switch at a time. look for a disconnected wire, or a loose wire. If the wires were pushed into the clip on the switch check carefully as these little clips often fail after a while.
I seriously think you will find a loose wire and that will solve your problem, once you reconnect it.
If that is not the case, you will have to replace one switch at a time until you have replaced the bad one.
I recommend that you make a diagram of each switch once you have it out in the open noting which color of wire goes to each screw or spot. You will always have one screw on a switch which is a slightly different color from the rest. Always note which color wire goes to the odd color screw and make sure you always hook that wire to the odd color screw in the new switch.
1 Related Answer
Anonymous
  • 351 Answers
  • Posted on May 25, 2010
SOURCE: Replacing a pull chain 3-way ceiling fan light switch
OK .. the thick black and white are the power for the fan , are there also white wires on the lamp sockets ..??
The thick black wire should connect to the black wire on the switch.
The small black wires connect to the red and blue wire on the switch .. two small black wires each .. that should give you a position for 2 lights , and 4 lights, on the step switch .. but there should be white wires from the lamp sockets connected to the thick white from the fan .
please respond .
Please Vote !!
Testimonial: "I appreciate the response, which reinforced my thought process and it worked - Thanks!"
Concord fan lights work, fan only at low speed.
Based on the information provided, it is possible that the issue lies with the Zing Ear ZE-208D 3 speed switch. This switch controls the fan speed and if it is not functioning properly, it could cause the fan to only run at the lowest speed. It is also possible that there could be an issue with the transformer or another component, but without further testing it is difficult to determine the exact cause of the problem.
One potential solution would be to replace the Zing Ear ZE-208D 3 speed switch. This can be done by disconnecting the wires from the old switch and connecting them to the new switch in the same configuration. It is important to ensure that the new switch is compatible with the fan and has the same number of wires as the old switch.
Another potential solution would be to check the wiring connections between the switch and the fan motor. Loose or damaged connections could cause issues with the fan speed.
If neither of these solutions work, it may be necessary to consult a professional electrician or contact Concord for further assistance.
Apr 29, 2023 • Dryers
1helpful
I need a 3-speed fan switch for a Holmes stand fan #HASF1522
Just a thought
If you find a junker fan try the switch off of it. Quite often they will work. Sometimes different makes the switches are interchangeable.
1helpful
Need a wiring diagram for 3 speed patton floor fan
A three way switch has 3 terminals, these for floor fans operate by a rotary switch but can be adapted to use any 120V Rotary toggle or rocker type switch. technically your compartment (or room provided will determine which to use). I'd suggest you replace it with one like the one that no longer works. The one good thing about fans the direction they rotate in is already determined, and with a/c current it will work even if you connect it up wrong! If it work's then fine don't over think it
2helpful
What is the correct way to hook up a TM813-WCCS? I have one lead from the downstairs 3-way switch - black/red/white, and a fan lead - black/white. I can get the 3-way switches to work, but no luck adding...
Not enough information is given.
TM813 is combo switch with single-pole and 3-way. So switch has two different rocker-switches on face, and one controls 3-way circuit and one controls single-pole circuit.
You are controlling a light and a fan.
You have successfully connected lights to 3-way switch.
Are you trying to connect fan to single-pole switch?
Add a comment and say what you are connecting, and what type of switch you are replacing, and what each wire tests, and what terminals are on switch and what wire you have connected to each terminal so far.
1helpful
The Casablanca 88U33M Scandia Ceiling Fan only has three wires, a black, a white, and a green wire (ground). How do you wire the fan and light on seperate switches?
If you want to control both the light and the fan using 3-ways, then just wire 2 sets of the 3-way circuits. For this you need two sets of 3-wire between the switches, and one 3-wire cable from the switch location to the fan/light box.
At box #1 (a 2 gang box), you will run a power cable (marked cable #1) into it. From there you run 2 sets of 3-wire cables (identified as cable #2 & cable #3) to the other switch location, which will also be a 2-gang box (box #2).
Also from box #1, you will run a 3-wire cable (cable #4) to the fan/light box (box #3).
Hook up is as follows:
Box #3: connect black of cable #4 to black (fan), connect red of cable #4 to blue (light), connect white of cable #4 to white (fan/light), and connect the bare to the green.
Box #2: Connect white of cable #2 to identified terminal on 1st 3-way switch (#3). Connect red & black of cable #2 to the remaining screws of 3-way switch #3. Next connect white of cable #3 to identified terminal of 2nd 3-way switch (#4), and connect black and red to remaining screws. Tie all grounds together and terminate to both switches.
At box #1, connect black from cable #1 to whites in cables #2 & #3, using a wirenut. Connect white in cable #1 to white in cable #4. Connect black and red in cable #2 to 3rd 3-way switch (#1) and connect black and red in cable #3 to 4th 3-way switch (#2). Connect black in cable #4 to identified terminal of 3-way switch #1, and connect red in cable #4 to identified terminal on 3-way switch #2. Tie all grounds together and to the switches
Our hunter fan won't work on high speed any longer, low and medium speed work fine, when clicked on high - it only goes at medium
Sounds like the variable speed switch may be worn out.
You should be able to purchase replacement switch at the local home depot- type store in the electrical supplies.
Trying to get an exact match to replace may be a bit difficult, but a similar 3 speed switch should work just fine.
Can't use Wall Switch to turn on light
The problem may not be with the fan, but with the wall switch. Try changing the wall switch and see if that works, sometimes they go bad.
12helpful
3answers
UC7078T Remote
try opening remote control
vary (4) "dip" switch(s) positions
when I opened mine-all four were up
I moved the 2nd switch down and it worked!
1helpful
2answers
Trying to replace 3 speed ceiling fan switch and don't know which wires go where - 3 speed fan switch, 4 wire unit.
Hi
The pull switch has 4 wires, L, 1, 2, 3.
Connect ' L' to the reverse switch red wire or the wire that is free.
Connect ' 3 ' to the main black ( hot ) wire entering the fan.
Connect ' 1 ' to the capacitor's lowest uF eg. ( 1.5 uF )
Connect ' 2 ' to the capacitor's next uF eg. ( 3 uF )
the Capaciotr also has to be connected to the neutral wire entering the fan, usually black attached to another color wire. If you have a VOM tester, veryfy that it is a neutral wire.
Regards
H. Montero
Top Leviton Electrical Supplies Experts
john h
Sean Wright
Sean Wright
CJ Rock
CJ Rock
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
