Question about MicroBoards Office Equipment & Supplies
Microboards pf2 will not print
Pf2 printed ok yesterday, using microboards ink, today, the paper cd feed light keeps blinking........won't print----
downloaded the driver from microboards, still no luck...
any ideas?
I whant drivers this printer
Posted on Apr 03, 2008
SOURCE:
Green light flashes 7 times
LED Blinking in Orange/Green:
2 times: No paper. (ASF) [1000]; Set the paper in the ASF, and press the Resume/Cancel button.No CD-R tray. [1001]*1; Set the CD-R tray, and press the Resume/Cancel button.
No paper in the cassette. [1003]; Set the paper in the cassette, and press the Resume/Cancel button.
3 times: Paper jam. [1300]; Remove the jammed paper, and press the Resume/Cancel button.
Paper jam in the under guide. [1304]
Paper jam in the rear guide.[1303]
Front door closed. [1250]; Open the paper output tray.
4 times: No ink.[1601 / 1611 / 1612 / 1613]; Replace the empty ink tank(s), or press the Resume/Cancel button. Pressing the Resume/Cancelbutton will exit the error without ink tank replacement, however, ink may run out during printing.
5 times: The print head is not installed [1401], or it is not properly installed (EEPROM data of the print head is faulty) [1403 /1405]. Install the print head properly, and close the access cover. Or, with the print head installed, turn the printer off and on.
6 times: Inner cover open. [1841]*2; Close the inner cover, and press the Resume/Cancel button.
Inner cover open (during printing on paper). [1846]*2; Close the inner cover, and press the Resume/Cancel button.
CD-R tray guide closed (during CD-R printing).[1850 / 1855]*1; Open the CD-R tray guide, set the
CD-R tray properly, and press the Resume/Cancel button.
CD-R tray guide open (during printing to paper). [1851 /1856]*1; Close the CD-R tray guide, and press the Resume/Cancel button.
7 times:No CD-R or DVD-R. [1002] After setting a CD-R or DVD-R in the tray, set the tray in the tray guide, and press the Resume/Cancel button.
8 times: Warning: The waste ink absorber becomes almost full (approx. 95% of the maximum capacity). [1700]; Pressing the Resume/Cancel button will exit the error, and enable printing. The service call error, indicating the waste ink absorber is full, is likely to occur soon.
In repair servicing, replace the bottom case unit (QM2-1249), or the ink absorbers (QC1-4222 / 4223 / 4224 / 4263 / 4264 / 4864).
9 times: The connected digital camera or digital video camera does not support Camera Direct Printing. [2001]; After removing the cable between the camera and the printer, press the Resume/Cancel button, and
re-connect the cable.
10 times: Automatic duplex printing cannot be performed (paper size not supported). [1310]; Press the Resume/Cancel button to eject the paper being used at error occurrence. Printing will resume from on the front side of the next page.
11 times: Failed in automatic print head alignment. [2500]; Press the Resume/Cancel button, and after confirming the following, perform print head alignment again: - Set an appropriate type and size of paper (plain paper, A4 or letter). - Check that the nozzle check pattern is properly printed (all ink ejected, no faint printing). - Protect the paper output slot from exposure to excessive light.
Access cover open. [1200]; Close the access cover.
LED Blinking in Orange and Green Alternately, or Lit in Orange:
2 times: Carriage error [5100]
3 times: Paper feed error [6000]
4 times: Purge unit error [5C00]
5 times: ASF (cam) sensor error [5700]
6 times: Internal temperature error [5400]
7 times: Waste ink absorber full [5B00]
8 times: Print head temperature rise error [5200]
9 times: EEPROM error [6800]
11 times: Carriage lift mechanism error [5110]
12 times: AP position error [6A00]
13 times: Paper feed position error [6B00]
14 times: Paper feed cam sensor error [6B10]
15 times: USB Host VBUS overcurrent [9000]
16 times: Valve sensor error [6C00]
17 times: Motor driver error [6D00]
20 times: Other hardware error [6500]
Continuous alternate blinking: rom error
Aug 31, 2014 | Canon PIXMA iP2000
My canon pixma ip2000 lights flashing 7 times
LED Blinking in Orange:
Doesn't want to print
Try unplugging from the wall for 5 minutes / plug in and retry, cancels / resets printer memory.
Feb 17, 2010 | Canon BJC 3000 InkJet Printer
My Microboards PF2 does not print color properly.
The next to last cartridge I installed did not print properly. It seemed like all the colors were not there so I weighed it on a postage scale and it weighed less than another new one I had. I called Microboards. They said to send it to them and they replaced it. It may not be that, but weighing it should give some indication if it is.
Dec 07, 2009 | MicroBoards PF-2 Disc Printer
Pf2 not printing red ink with new cartridge # PRF38ML
Defective cartridge, contact Microboards and they'll send you a replacement for free if there is more than 80% of the ink still left.
May 27, 2009 | MicroBoards PF-2 InkJet Printer
Black ink too heavy - Microboards PF2
you can adjust the dry time. go to printer and faxes and right click select preference, there should be tabs select features then below should be advance features select that and there you can adjust the dry time and amount of ink.
Jan 18, 2009 | MicroBoards Print Factory InkJet Printer
PF-2 Won't detecd cd
First try re-installing the PF-2 print drivers. If that doesn't work, then try a different ink cartridge. If you have printed more than 5000 discs in the printer, it just may need a good cleaning as the sensors would be full of dried ink.
www.techwaredist.com
Nov 07, 2008 | MicroBoards PF-2 InkJet Printer
Pf2 ink cartridege recognition issues
Sounds like you have either a defective ink cartridge, or the sensor that recognizes the cartridge is either dirty, broken or out of alignment.
Microboards will help you out at no charge if your printer is still under warranty. Otherwise you can contact an authorized Microboards repair center like
http://www.techwaredist.com/repairshop.asp
Apr 29, 2008 | MicroBoards PF-2 InkJet Printer
Dvd feeding problem
The reason you are having trouble with DVD's and not CD's is that the DVD's are a little thicker or taller than the CD's. The area above the belt system has to be adjusted upward. this adjsutment is not in the manual, and is complicated. My company, Techware DIstribution, has had as many as 20 of the PF-1 and PF-2 printers running in our production and demo room. We can walk you through the steps to make the adjustment if you like.
Contact info: http://www.techwaredist.com/repairshop.asp
Mar 24, 2008 | MicroBoards PF-2 InkJet Printer
Disc Feeding Problem
I am assuming you are using a PF-2 printer. If you are using a standard HP78 ink cartridge instead of the Microboards cartridge, the unit will only print approx 5 discs before it stops. The microboards cartridges have a security tag under the barcode label that is scanned by a magnetic reader on the left hand part of the unit. If you are careful, you can use a razor blade and remove the label from a microboards cartridge and tape it on the front of a HP ink and save yourself about $25 an ink cartridge...
Nov 29, 2007 | MicroBoards PF-2 InkJet Printer
521 people viewed this question
Top MicroBoards Office Equipment & Supplies Experts
kevin gabrik
kevin gabrik
Level 1 Expert
Marvin
Marvin
Vladimir Frolov
Are you a MicroBoards Office Equipment and Supply Expert? Answer questions, earn points and help others
