After 30 minutes of use, sony vaio CR-510E system becomes hot and shutdowns automatically.
I am not sure if the shut downs is due to the heat produced with in the system. However I have observed that system is abnormally hot when it gets shutdown. I have to reboot after leaving the system for 30 minutes to get back to room temeperature...
Kndly help me to fix this problem.
Thanks
Vicky M
More than likely the fan above the processor is not working. Or the vents are clogged on the computer case due to dust/dirt. Ventilation.Check the fans.
Do not operate the computer on a bed or other soft surface
it needs to be on a hard surface in order for the vents to work properly
you might also want to use a laptop pad that has it's own fans for more ventilation.
also use a vacuum to clean the dust out of the vents
good luck
