Change your keybord layout in control panel->regional settings.
Then if still same thn your laptop keybord has issue because anothr usb keybord works fine.
There is not issue with operating system you need to repair your laptop key bord.
If it is warrenty you can use warrenty
Let me know if you need further assistance.Thanks for using fixya.
Part numbers may be positioned on your Acer TravelMate 2354LM Cooling FAN or you can look at user's manual. A way to pay attention to compatibility is always to look at the listing from the "Fits the next model." Their email list gives you the product model that could be compatible with the List item. The only way to check if this replacement part is useful for you or you cannot, your product's Part Numberhave to become the identical with his part number. Whether or not it's on the list, then it will likely be compatible. (Your Deivice Model number is just not good enough to verify correct product). Part numbers might be situated on your Compaq Presario M2007AP Power Jack or you can look at user's manual
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts
or if this does not fix the problem
control panel keyboard you can change your settings there
or you might have uninstall the keyboard then reinstall it and its drivers
control panel keyboard hardware then properties you hould see driver details,update driver,roll back driver,uninstall
make sure you have the driver for the keyboard before uninstalling the driver
make sure the lead is good and has a secure connection diconnect the keyboard then reconnect it then reinstall the driver
hope this helps
