ASUS A6U Notebook Logo
Posted on Nov 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Asus K60ij laptop and I cannot eject my
I have a Asus K60ij laptop and I cannot eject my memory card from the slot
Anonymous
Level 2:
  • Expert 83 Answers
  • Posted on Nov 22, 2009
Anonymous
Expert
Level 2:
Answers
83
Questions
0
Helped
19731
Points
255
If when you press the card in to eject it, it doesn't come out, you can use a pair of tweesers to gently pull the card out. There are no mechinisims holding it in place.
Mitesh Kr Anand
Level 3:
  • Master 497 Answers
Mitesh Kr Anand
Master
Level 3:
Answers
497
Questions
0
Helped
184101
Points
1465
Push the Memory Card to eject the Memory Card from the Memory Card slot of the Computer.
Good Luck!!!!!!!!!!!!!
How to remove/load sd card stuck in Huawai M860
The SD memory card slot is spring loaded, to insert the memory card insert the card into the SD memory slot with the SD card contacts going in first and gently push it in until it locks in place. NOTE if the SD card does not slide into the slot easily then the SD memory card has been inserted back to front, turn the SD card around and insert it again.
To remove an installed SD memory card, press the SD memory card and it will pop out slightly then you can then pull out the SD memory card.
Mar 12, 2013 • Cameras
2helpful
How do lock my laptop mouse pad on my ASUS Notebook K60IJ?
you have a small button on either the left or right side of your power button. It will be orange if it is disabled. Press the button once and you should then be able to use your mouse.
Please leave rating and/or feedback if you found this helpful
Thanks!
How do i get my Asus k60ij camera to work
There is a program that should be installed on your computer called ASUS LifeFrame. Its located under ASUS Utilities which is under "All Programs"
Misc card stuck in slot, how do i get it out ?
1. Shut Down The laptop
2. Remove the laptop Battery ( Close the Lid , turn the laptop Up side down, search for a battery Lock tab, move it to Unlock position, You can see a Lock/Unlock mark on the Laptop cover, this will eject the battery from the slot.
3. Get a tweezers carefully pullout the memory card from the card slot, utmost care should be taken not to damage the card slot contacts
4. After taking out the card put back the battery make sure that it is in the locked position
5. Start the computer , try out the system
6. Verify the memory Card reader functionality using a proper card as per the maker guidelines
How do I load M2 memory card into asus X71Q laptop? there is no slot for the M2adaptor
hi frnd.. try getting a usb memory card reader tat will help u... Take care...
My son put the wrong memory card in the flash
turn off computer, unplug gently use needle nose pliers and slowly tug out and rock a little
I have a simple question. How do I insert my scandisk memory stick pro duo card into my laptop to read? MY laptop has open slot 5 in 1 media card reader. I can insert all my other card and able to read....
You need an adapter that will convert it into a regular pro duo card. They usually come with the card when you buy it but else should be availabe at you local electronics store.
Memory Card
Did you try pushing it a bit in to see if it ejects out?
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
