SOURCE: i can't download dvd's to my coby mp610 mp3 player
you may use Nidesoft DVD Ripper to do it. this software can convert dvd to all popular video and audio format in high quality at fast speed, you may try to use it to download your dvd movies to your mp3 player.
free download this software here and have a try:
http://www.nidesoft.com/dvd-ripper.html
hope this information is helpful to u
SOURCE: Deleting files is not creating free space on my coby mp705-8g mp3
Ok First, Open Your MP3 player
2) Go To Setup
3) Then Go to system
4)Then Usb Mode
5) there will be auto or MSC
6) choose msc and then plug it in the files will be there.
SOURCE: Windows not Recognizing COBY MP705-8G
Make sure you have plugged your Coby MP3 player into a USB 2.0 port. The Coby does not support the USB 1.0 standard. If you are getting an error that "This device can perform faster..." your port is an older USB type. I have both types on my computer and the Coby would not install until I plugged it into my 2.0 port.
Hope this helps.
SOURCE: i have a frozen Coby MP610 8G how do i fix it?
Here are instructions for a solution to your frozen Coby 610 problem.
Replacing the firmware of your Coby 610 MP3 Player will unfreeze it and help it act normally again. This will also fix the 'File System Error' that has been popping up with some Coby 610 players. You can find it at the cobyusa.com website by choosing 'Mp3 & Portable', then 'Mp3 & Mp4 Players', then your model 'MP610', from the support page. Or, here is the direct link to the file from Coby's servers.
Unpacking the zipfile from the Coby Website will give you a PDF file with instructions, and a program file to run.
Your
music will be erased when you run this firmware update. The
instructions suggest that even if your mp3 player won't startup
properly, if you plug it into your computer you should be able to
access it as a removable disk, and copy all your music to a temporary
folder on your computer.
Here are the steps:
You can refer to this Coby 610 solution here.
I hope that helps.
SOURCE: file system error FAT is corrupted
Hi
This is the best solution i found so far...
i have an Archos 5....i went to : TOOLS - SETTINGS - CUSTOMER ASSISTANCE - REPAIR and FORMATTING TOOLS - REPAIR SYSTEM - clear temporary system files and cache..! (At the repair system page, you will get all options like "Reset Settings;Format harddrive;Full reinitialization etc...So u can choose what suits you best, n ALAS! Your achos will be back to normal....
Cheerz..
Roscoe
