Hi, i have a Short circuit on a fujitsu siemens Amilo D 8830 on the charger port, and i really need assistance on how to fix it as my current laptop is dying. I don't want to replace the laptop or any of its parts, i would rather repair it. Please help ASAP!
Thanks in advance
Pete
SOURCE: fujitsu siemens amilo pro keyboard replacement
Hi is that you want to replace the existing keyboard from your mom's laptop ? if so right above the keyboard you will find a removable plastic panel (it is fragile breaks very easily so be carefull ) which would secured in place with snap on plastic locks or 3 screws would be securing it in place which you can see on the rear of the laptop , if the battery compartment is under the top portion then remove the battery you can see these screws . In any case please take your OWN TIME TO ANALYZE and only then attempt this. If you are succesfull in doing this then remove the other screws visible that holds the KB in place and lift up the KB slowly because the connecting cable is flexible PCB and you could easily TEAR IT OFF if you pull hard . The Connector also needs lot of attention - very thin and small release the side catches by lifting it with a watch screw driver very slowly else you will end up breaking it . If you have come to this stage GREAT replacing KB is reverse of all this procedure.
SOURCE: how to replace cmos battery
hi dear
try this site
http://repair4laptop.org/disassembly_fujitsu.html
thx
cropp
SOURCE: I have a Fujitsu Siemens Amilo Li 2727. The
Try downloading the automatic driver update tool from the website.
This should normally fix this problem by updating all drivers.
